#2191 | ||
![]() Join Date: Jan 2005
I'm looking for a solution to the corroded Coolant bypass tubes on a AU Windsor.
Similar to these EB ones. ![]() Is there a source for them or failing that, is there a workaround?
I love Holdens.... |
#2192 | |||
#2193 | ||
are the heater cores still available for FG's or do we have to go non genuine jayrad now?
anyone know the part number ? |
#2194 | ||
#2195 | ||
Mk1.. looks like jayrad it is thanks
#2196 | ||
Hey mate,
These eight bolts, they’re the self tapping type. What’s their availability status, price? |
#2197 | |||
BA Ute Tub Parts.png |
#2198 | ||
Is HM1 a bolt?
I’d think size is about M8x30mm, they’re a thread-forming trilobular bolt with probably a 10mm hex head. Else it will likely be on the page that has the tub/sheetmetal elements. |
#2199 | |||
Trying to find a pic but no luck. No bolts in sheet metal section. BA Ute Tub Frame.png |
#2200 | |||
If so they are available at $5 each. |
#2201 | ||
![]() Join Date: Oct 2006
For the coolant bypass tubes on a AU Windsor this may fit (ebay Motors USA) https://www.ebay.com/itm/18589516492...Bk9SR_zlqezyZA Especially if the part number is similar.
regards Blue |
#2202 | |||
This should be the right one? BA Ute Bolt.png |
#2203 | ||
Hi mate,
It’s going to be a couple of days until I can pull up the back of a tub liner and document what’s there. My vague memory from about 2018, was that it had TapTite bolts holding the metal down, very similar spec to the tailgate hinge bolts but possibly one size smaller. Definitely the ones affixing the liner to the metal were something like your image. |
#2204 | |||
#2205 | ||
Thanks once again to GTLEGEND, this time for helping me with a key issue.
That image came from the WSM on this site; I think B-series, probably BA. |
#2206 | ||
Hi GT Legend can you supply this part?
P Platers make good moving targets. |
#2207 | |||
Looks to me its part of the cover itself as per image below. You cannot buy separate. $110 plus postage. SZ V6 Diesel Timing Belt Cover.png |
#2208 | ||
Diesel Sniffer
Hello GT, could u give price & availability on a tail shaft for a SZ MK11 Diesel tailshaft
#2209 | ||
#2210 | ||
Diesel Sniffer
#2211 | ||
Hi GT Legend. Are you able to source/price a rear door- drivers side door seal on a MY10 FG sedan. the seal required is the one mounted on the door that has the thin rubber dust flap just above the little quarter window. part number would also be great. thanks in advance.
#2212 | |||
Yeh should be able to source, just need to confirm. $90 plus freight, part number BGF25324A. This is the seal that sits on the door itself and goes all the way around the door as opposed to the one that goes around the door opening. GT |
#2213 | |||
I don’t think he’s talking about the rubber seal on the door, but rather the trim strip with the dust seal on it that attaches to the outside of the door frame all along the top. You know, the really expensive ones ![]() Sent from my iPhone using Tapatalk
-15 Ford Falcon FGX XR8 Auto -14 FPV Pursuit Ute #47 Auto -12 FPV Pursuit Rspec #44 Manual -11 FPV GS Ute #225 Manual -10 FG XR8 Ute Manual Sold -06 BF XR8 Ute -75 XB Falcon Coupe 351 GT replica -73 Ford Mustang convertible 351 -20 Ford Mustang GT Convertible |
#2214 | ||
If its the window frame moulding, is it black or chrome? Black for all except G6 G6E GTE F6E which are chrome. Confirm which one and we can go from there.
#2215 | ||
What's your price and availability for 2013 FG MK II Manual XR6 Clutch Master Cylinder and Slave Cylinder each or together please? I have as part numbers BA 7A5 43A and BA2 7A 508A but correct me if they are wrong.
regards Blue |
#2216 | |||
Part numbers you provided are correct. Master Cyl is available and I can get for $560 plus postage. Slave Cyl is also available and I can get for $1090 plus postage. GT |
#2217 | ||
George
![]() Join Date: Jun 2015
Hi GT,
Is it possible for you to get the key cutting code for my car keys? PM sent, thanks, George
BFWSM https://www.fordforums.com.au/vbport...articleid=1708 http://fordforums.com.au/wsmpub/ba/501-05.html ![]() R/U 2019 ![]() ![]() ![]() PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI. 1997 Fairmont EL Ghia Tickford 4L Auto ![]() 1985 Falcon XF GL 4.1L Auto. 1979 Fairmont XD Ghia 4.1L Auto. 1971 Cortina GL Estate Manual. |
#2218 | ||
George
Thanks GT
#2219 | ||
![]() Join Date: Nov 2011
Hi Legend,
Any chance of factory books for an FGX G6E? |
#2220 | ||
