Go Back   Australian Ford Forums > The Sales Yard > Spare Parts and Other Accessory Items > Genuine Ford Parts
Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member.
Old 02-12-2024, 11:12 AM   #2191
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
Default Re: Genuine Ford Parts
I'm looking for a solution to the corroded Coolant bypass tubes on a AU Windsor.
Similar to these EB ones.
Is there a source for them or failing that, is there a workaround?
I love Holdens....
cs123 is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2024, 12:14 PM   #2192
GTLEGEND
Not aware, it had a part number of F8RE9D424AA. ill see if I can find anything but not aware at the moment.
Old 02-12-2024, 07:39 PM   #2193
v1rus
are the heater cores still available for FG's or do we have to go non genuine jayrad now?
anyone know the part number ?
v1rus is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2024, 10:27 PM   #2194
GTLEGEND
What model FG?
FG1 is obsolete BA18B539A, FG2 is still available BR2Z18B539AA.
Old 02-12-2024, 10:47 PM   #2195
v1rus
Mk1.. looks like jayrad it is thanks
Old 05-12-2024, 01:03 PM   #2196
Hey mate,
These eight bolts, they’re the self tapping type. What’s their availability status, price?
Old 05-12-2024, 02:33 PM   #2197
GTLEGEND
Originally Posted by Citroënbender View Post
Hey mate,
Can you see the bolts in the image below?
Old 05-12-2024, 04:16 PM   #2198
Is HM1 a bolt?
I’d think size is about M8x30mm, they’re a thread-forming trilobular bolt with probably a 10mm hex head.
Else it will likely be on the page that has the tub/sheetmetal elements.
Old 05-12-2024, 06:00 PM   #2199
GTLEGEND
Is HM1 a bolt?
HM1 Is described as a bolt and it says you need 4 of them?
Trying to find a pic but no luck.
No bolts in sheet metal section.
Old 05-12-2024, 09:55 PM   #2200
GTLEGEND
Is HM1 a bolt?
What about HS3? I am trying to get an image of one to compare.
If so they are available at $5 each.
Old 06-12-2024, 12:26 AM   #2201
For the coolant bypass tubes on a AU Windsor this may fit (ebay Motors USA) https://www.ebay.com/itm/18589516492...Bk9SR_zlqezyZA Especially if the part number is similar.
Old 09-12-2024, 10:36 PM   #2202
GTLEGEND
Is HM1 a bolt?
I am sure HS3 is what you need, can get $5 each.
This should be the right one?
Old 09-12-2024, 11:25 PM   #2203
Hi mate,
It’s going to be a couple of days until I can pull up the back of a tub liner and document what’s there. My vague memory from about 2018, was that it had TapTite bolts holding the metal down, very similar spec to the tailgate hinge bolts but possibly one size smaller. Definitely the ones affixing the liner to the metal were something like your image.
Old 13-12-2024, 10:10 AM   #2204
Phil67
Phil67's Avatar
Hey mate,
Hi mate, I need to replace my tub on my Fg for a viv so I need to document it thoroughly. Where did you get that picture and info?
Phil67 is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2024, 12:29 PM   #2205
Thanks once again to GTLEGEND, this time for helping me with a key issue.
That image came from the WSM on this site; I think B-series, probably BA.
Old 30-12-2024, 10:18 PM   #2206
fastbaja5b
Hi GT Legend can you supply this part?
P Platers make good moving targets.
fastbaja5b is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2024, 11:35 PM   #2207
GTLEGEND
Hey mate,
Looks to me its part of the cover itself as per image below. You cannot buy separate.
$110 plus postage.
Old 30-12-2024, 11:38 PM   #2208
goz007
Diesel Sniffer
goz007's Avatar
Hello GT, could u give price & availability on a tail shaft for a SZ MK11 Diesel tailshaft
goz007 is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2024, 06:02 AM   #2209
GTLEGEND
Hey mate,
I think they are obsolete, will need to look at it further at get back to you in the new year.
GT
Old 31-12-2024, 10:44 AM   #2210
goz007
Diesel Sniffer
goz007's Avatar
Originally Posted by GTLEGEND View Post
Hey mate,
GT
Thankyou
Old 06-01-2025, 03:11 PM   #2211
FPV 460
Hi GT Legend. Are you able to source/price a rear door- drivers side door seal on a MY10 FG sedan. the seal required is the one mounted on the door that has the thin rubber dust flap just above the little quarter window. part number would also be great. thanks in advance.
FPV 460 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2025, 04:57 PM   #2212
GTLEGEND
Hey mate,
Yeh should be able to source, just need to confirm. $90 plus freight, part number BGF25324A. This is the seal that sits on the door itself and goes all the way around the door as opposed to the one that goes around the door opening.
GT
Old 06-01-2025, 06:09 PM   #2213
gpierce
gpierce's Avatar
Hey mate,
GT
I don’t think he’s talking about the rubber seal on the door, but rather the trim strip with the dust seal on it that attaches to the outside of the door frame all along the top. You know, the really expensive ones
Sent from my iPhone using Tapatalk
-15 Ford Falcon FGX XR8 Auto
-14 FPV Pursuit Ute #47 Auto
-12 FPV Pursuit Rspec #44 Manual
-11 FPV GS Ute #225 Manual
-10 FG XR8 Ute Manual
Sold
-06 BF XR8 Ute
-75 XB Falcon Coupe 351 GT replica
-73 Ford Mustang convertible 351
-20 Ford Mustang GT Convertible
gpierce is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2025, 06:30 PM   #2214
GTLEGEND
If its the window frame moulding, is it black or chrome? Black for all except G6 G6E GTE F6E which are chrome. Confirm which one and we can go from there.
Old 07-01-2025, 01:53 PM   #2215
What's your price and availability for 2013 FG MK II Manual XR6 Clutch Master Cylinder and Slave Cylinder each or together please? I have as part numbers BA 7A5 43A and BA2 7A 508A but correct me if they are wrong.
Old 07-01-2025, 03:00 PM   #2216
GTLEGEND
Hey mate,
Part numbers you provided are correct.
Master Cyl is available and I can get for $560 plus postage.
Slave Cyl is also available and I can get for $1090 plus postage.
GT
Old 10-01-2025, 12:03 PM   #2217
BFIIGhiaZF6
George
BFIIGhiaZF6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: The experience, information and willingness to help and share data in regards to the ZF cooling system options has probably cleared a lot of doubt about air/oil coolers and the ZF transmission.
Hi GT,
Is it possible for you to get the key cutting code for my car keys?
PM sent, thanks, George
BFWSM
https://www.fordforums.com.au/vbport...articleid=1708
http://fordforums.com.au/wsmpub/ba/501-05.html
2007 BFII Fairmont Ghia I6 4L, ZF6 Auto, Ego Charcoal, Warm Charcoal.
R/U 2019:Winner 2023 2025:, Best BA-BF Geelong AFD.
PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI.
1997 Fairmont EL Ghia Tickford 4L Auto
1985 Falcon XF GL 4.1L Auto.
1979 Fairmont XD Ghia 4.1L Auto.
1971 Cortina GL Estate Manual.
BFIIGhiaZF6 is online now   Reply With Quote Multi-Quote with this Post
Old 10-01-2025, 07:30 PM   #2218
BFIIGhiaZF6
George
Thanks GT
BFWSM
Old 10-01-2025, 11:44 PM   #2219
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
Hi Legend,
Any chance of factory books for an FGX G6E?
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2025, 11:58 PM   #2220
GTLEGEND
Originally Posted by PridenJoy View Post
Hi Legend,
Can get NOS set, not cheap at $220 though.
