Old 30-04-2017, 10:12 AM   #1
brucewarring
Default LS Focus Ghia Horn
I am being careful, my horn isnt working, I have checked the horn, fuse and relay and all good. It is probably in the horn button area and I dont know how to remove it or is the air bag going to go off...Help the old bloke please....Bruce
brucewarring is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2017, 05:18 PM   #2
DZFord
DZFord's Avatar
Default Re: LS Focus Ghia Horn
Here is the workshop manual extract from the Technical Resources section, on LS Focus horn diagnostics https://fordforums.com.au/wsmpub/lsf55/413-06.html
The last page states that the actual horn switch is integrated with the drivers airbag module.
Old 01-05-2017, 06:39 PM   #3
marg99
Och that sounds expensive if the fault is within the airbag unit. May be you can get a good secondhand one from the wreckers?
Old 02-05-2017, 07:43 AM   #4
brucewarring
Thanks for that info DZ I did read it and was unsure if I could get it off without letting the airbag off, the next query is if I got a second hand one from the wreckers can you just fit it or does Henry Ford have to set it up....Bruce
