Old 05-03-2012, 10:18 PM   #1
oysta
Escort MkII 1977 2.0L
Default Good to be back again...with a 'new' Escort (see pics)
Hi guys,
Well after being absent for a couple years it's good to be back...this time with a '77 Esky.
I'm located in Adelaide (South) for my fellow Esky community.
And now for my first issue :(
The steering is quite loose when driving. I can wobble the steering wheel with no reaction from the wheels. My previous mk2 was quite tight.
When stationary, it's doesn't seem to have any play.
Tie rod ends? rubber rack mounts? rack/pinion? Where to start?
Oysta
oysta is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2012, 09:09 PM   #2
wicko
wicko's Avatar
Default Re: Good to be back again...with a 'new' Escort (see pics)
Could be all of those - I'd start by putting it off the ground and getting someone to turn the wheel while you look up at what is/isn't happening.
They are pretty basic so you should be able to make some big imrpovements pretty quickly. Don't discount well worn rubbers either.
Local Tyre Franchise told me I needed a new balljoint, 2 mechanics and a suspension shop later and no one reckoned the ball joint was bad. I got the kids to swing on the wheel and guess what - Ball Joint!
wicko is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2012, 10:06 PM   #3
XP6
Formerly ST170ish
XP6's Avatar
What are the front tyres like?(are they the same type tread with even wear)
XP6 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2012, 02:58 PM   #4
oysta
Yeah, tires are the same tread and wear. However they are quite wide, I think they're 205's from memory...same front and back.
What I dread is starting to replace parts only to find I've changed a handful of items before finally getting to the culprit...Murphy's Law.
Old 08-03-2012, 10:13 AM   #5
feral
He's not exactly close to you, but Mike Dale of Mike Dale Automotive in Holden Hill has raced escorts for years and knows them back to front. If you went and saw him, I am sure you will get a no bs answer. There are a few boys from down south over here who may be able to point you to someone closer:
http://www.classic-ford.org/forum/
ZJ Fairlane 351C
SY Territory
Skicraft Excel 350 Mercruiser
feral is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2012, 12:39 PM   #6
oysta
Thanks Feral
Old 14-03-2012, 05:20 PM   #7
oysta
So had a look under the esky while the lady turned the wheel. The steering rack mount bushes look like they've had it and the whole rack moves side-to-side. So I think I'll start with some new bushes. I'm leaning towards Super Pro. Anybody have any opinions, experience, recommendations with brands?
Adam
Old 15-03-2012, 01:37 PM   #8
thebecbec
thebecbec's Avatar
Try Smcka Performance based in Sydney, but they have an online shop www.classicescortparts.com.au
Not sure about bushes, but they sell an amazing quick rack for about $250 from memory.
thebecbec is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2012, 01:48 PM   #9
oysta
Ended up getting a pair of nolathanes for $30 from Motormate. Was quoted $42 for super pro. I've heard Nolathane bushes have a stiffer material which can create a harsher ride but seeing these are going into the steering rack mount rather than absorbing impact somewhere in the suspension I think they should be ok. Now to install them...job for the weekend.
Old 21-03-2012, 08:54 AM   #10
cram72
I got a complete kit of superpro for 300 bucks off ebay, did whole car and steering knuckle.
cram72 is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2012, 12:39 PM   #11
CSWTH1
Becossie
CSWTH1's Avatar
It looks like a good car straight body etc you must be happy with that despite a couple of small problems, good luck with it mate
CSWTH1 is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2012, 01:34 PM   #12
oysta
Indeed I am happy. What fun would it be without a few problems
