Old 25-03-2008, 05:03 PM   #1
Pazuzu
Default Mk. 2 Essy rear swaybar bushes
Hi all.
I need to get some new bushes for the rear swaybar for the mk 2 Essy. I've been told by Pedders that they don't stock them, and that they're hard to find (Read: they couldn't be stuffed finding it.) Unfortunately, I can't get it registered until it's done.
Does anyone know where these can be found/ bought?
Pazuzu is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 06:29 PM   #2
Sterling
sorry mate my escort came with replaced bushings on the swaybar but the seller forgot to tell me so obviously they arent expensive and hard to find. just keep looking, good luck
oh and alot of swaybar bushes match other cars so do some research too!
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 07:34 PM   #3
ieatsports_cars
proud member of the MFCC
ieatsports_cars's Avatar
i just orded new front sway bar bushes for the el falcon ! i orded super pro bushes and i got them from supercheap auto
ieatsports_cars is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2008, 08:57 AM   #4
whooligan
whooligan's Avatar
Originally Posted by Pazuzu
Hi all.
Who says you can't register it? Just take the swaybar off....Its next to useless anyway.
If you insist on putting it back on give Yesterford a call on (03) 9761 4714. They do mail order and $70-80 (according to my price list) should sort you out.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2008, 06:07 PM   #5
Pazuzu
Thanks for the help, Whooligan. I've given them a call, and now just need to determine if it's the 12 or 14mm bar before ordering.
You've saved me a world of hurt, after a half- dozen phone calls to local suspension specialists no- one knew what the hell I was talking about.
Incidentally, it's not just the sway bar that got pulled up on Blue Slip inspection (changing it from NSW to QLD rego.) It's just something that needs to be fixed before I take it back for the second inspection.
Also got pulled up on: worn LH rear tyre, leaking diff pinion seal, reverse lights not working, driver's side winder knob broken, worn wiper blades, worn front brake flex lines, oil leak at the gearbox, loose battery, and rear window tint peeling off.
As you can see, its mostly housekeeping issues, but after pulling apart the wiring last weekend I waved the white flag and will have to get someone who knows what they're doing to have a look. I managed to get them working, it's just that they don't switch off when I take it out of reverse (hence my reverse light switch location post a week or so back.)
ahh, the joys of owning an older car!
Old 29-03-2008, 08:28 AM   #6
Regs RS
Regs RS's Avatar
Just finnished replacing just about every bush front & rear in the RS, mostly nolathane although the swaybar bushes i had to use superpro, the rear ones are 12mm. Got them all through a local firm Gibbo's auto parts in Lismore (thanks Jeff) all in a day or two if they wern't in stock as are most of the other parts i have needed
Regs RS is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2008, 10:39 AM   #7
boyracer
http://www.noltecsuspension.com/ check out this mob
boyracer is offline   Reply With Quote Multi-Quote with this Post
