Old 04-03-2008, 01:34 PM   #1
DOLMIO
Default Escort Thermo Fan Conversion
Howdy everyone, i have a mk2 2litre 4 door escort and i was just wondering what was the best way to get rid of the mechanical cooling fan and put a electric thermo fan in? What fan would be best fit and do i need a new radiator that fits with a few mods to the brackets? And also where do i put the temp sensors? Thanks
DOLMIO is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2008, 08:21 PM   #2
Royman
Just take to old fan off, measure your radiator to figure out the largest diameter fan you can fit (12inch 14inch etc) grab a universal fan which can be mounted on front or rear of radiator (reversable), fit it on which ever side you like. Escorts dont have thermo fan switches so you best option is to buy a aftermarket switch, these can be braised into the radiator or you can also buy a adaptor which you put in a radiator hose witch will take the switch (this is an easier option). Then your done...
Hope this helps
Royman is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2008, 08:45 AM   #3
EskyCosworth
RS2000 COSWORTH
If the engine is fairly standard, just leave the original, I played around with my daily driver with thermo fans and ended up with the original arrangement.
EskyCosworth is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2008, 06:52 PM   #4
oysta
Escort MkII 1977 2.0L
So your saying there are minimal gains in power from switching from the standard mechanical fan to thermofan setup? Is it only worth changing if you want more air flow for say a modified engine? I always thought the belt driven fan placed extra strain on the engine.
oysta is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2008, 04:48 PM   #5
Sterling
yeah, i used to think that, but even though it does turn out with more power in the end, with an electric fan, its not much, here it is, the mechanical fan puts a load on the engine and can overcool when starting an engine in the cold, but an electric fan is not as reliable, and it puts a load on the alternator so the load evens itself out its only when the electric fan is not on (when driving fast or coasting) that u get that little power difference.
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2008, 07:24 PM   #6
digginganddirt
trust me there a pain in the my m8 put one in his rolla 14" and its allways running to hot (well alot hotter than normal) the standard one is good if you took if of you might gain 1 hp lol not really worth the trouble
digginganddirt is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2008, 09:08 PM   #7
DOLMIO
Yeah not really going over the top with the engine so i guess its a good idea to leave the original one on, it would save me the pain anyway trying to get it to work properly anyway.
Thanks for your thoughts guys
