Old 20-04-2007, 02:28 PM   #1
chookaz_351
six shooter
Default 4 to v8
Hi guys i know this question has probably been asked a million times but here goes anyway.
Im interested in getting a hold of a 70's capri and putting an a 302 windsor. Im wondering what is involved in the swap. Is there a lot of engineering involved? I dont want an auto either i want to put a manual gearbox. Im a bit new to windsors, (im a clevland man) so what gearboxes work well single rails? toploader? maybe even a celica or supra 5 speed if im financial enough. Any info would be greatly appreciated
chookaz_351 is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2007, 05:30 PM   #2
cortina-mk1
Heavy right foot
cortina-mk1's Avatar
straight forward conversion
rod hadfield (rod shop) makes conversion kits to fit
he also has chassis strengthing kits as well
depends on how much yer have to spend
cortina-mk1 is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2007, 08:57 PM   #3
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Make sure you get an engineer lined up first, to get it approved. It should be straightforward, but they are clamping down on things more these days.
Old 21-04-2007, 07:13 PM   #4
FRA
Mr Focus
FRA's Avatar
It's good to see your putting in a Ford racing engine.
So your getting the 5.0L 302-340Hp GT-40 aluminum head. The Boss is back...lol
That's 224KW at the engine, that'll show XR owners whos Boss...hahaha.
What state do you live in?
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody
Oz racing: WRC OBX: 4-2-1 race header
SCT: xcal3, dash scan.
FRA is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2007, 01:53 PM   #5
chookaz_351
six shooter
well i hadnt decided on a donk yet but i had thrown around the idea of a crate engine. I think that will come later on tho just want to get the body sorted and and get the coversion done will worry bout gaining horses after that
Old 01-05-2007, 12:26 AM   #6
ClevoCapri
ClevoCapri's Avatar
Just put a clevo in it!!!!
Its too easy.
ClevoCapri is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 12:37 PM   #7
chookaz_351
six shooter
is it just as easy to put in a clevo? I honestly have no idea what is involved i just know that it has to have a v8. What is a conversion kit worth? Is it something that can be done in a the shed at home?
Old 01-05-2007, 04:56 PM   #8
ClevoCapri
ClevoCapri's Avatar
It is relatively easy if you have a few basic tools at home. Drills, engine crane ect. You can get conversion from a few places. I got mine from a bloke called Bob Pinell. He's in QLD. Didnt cost much to post to perth so im sure youl be ok. Thats if he still does conversion stuff. You can buy a sump and pick up from most sump manufacturers. Change the brake booster. Thats about it, apart from brakes ect.
Clevo's fit nicely. 302 weezers look tiny in the capri engine bay!
Brett
Old 01-05-2007, 05:16 PM   #9
FRA
Mr Focus
FRA's Avatar
go bigger then
Old 01-05-2007, 08:19 PM   #10
Capri351
Brett
Been there, done that too. I used the Castlemaine kit and as a source for everything including brakes. Fairly straightforward swap except if you want decent extractors you will have to get them custom made, or if you have the skills knock them up yourself as I did
Oh, and if you do go Clevo, don't skimp on the radiator, they do require a bit more in that department.
Why go 302 if you can go 351
Capri351 is offline   Reply With Quote Multi-Quote with this Post
