Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 09-03-2007, 01:51 PM   #1
Gunns
Gunns's Avatar
Default Brake upgrade for an EA falcon
Is there any brake upgrades out there for an EA? I all ready have slotted and cross drilled rotors with high temp pads. I am look for a twin piston setup or 4 piston setup on a 300mm rotor as I want to run my 16inch SVO wheels, otherwise I would run a 330mm rotor.
Cheers Al
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 02:00 PM   #2
Grasshoppr
GTI ist ehrfürchtig
Grasshoppr's Avatar
Yeah the best conversion is to do the twin piston Mustang caliper. Its the same one that the EL GT falcon used. I have this on my race car and I can tell you that it will stop you better than your current setup.
Good Luck
FPV & XR Owners Club of Victoria
Check out our website here
Our Events cater for all types of people.
Grasshoppr is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 02:28 PM   #3
Gunns
Gunns's Avatar
Good Luck
I was looking at that setup, though they run a 330mm rotor, which I have been told may (20% chance) or my not clear (80% chance) the 16 inch rim.
Old 09-03-2007, 06:57 PM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Yeah i don't know of a 300mm kit for these models only for the XY-XF.
I just sold a330mm twin piston kit now actually for an EF EL.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 09-03-2007, 07:03 PM   #5
LUXO_8
windsor user
what kind of money are we looking at for the 330mm twin piston setup
Old 09-03-2007, 07:14 PM   #6
FLOORED
Race Brakes Sydney
FLOORED's Avatar
This front kit is about $2500 fitted.Alone it is about $2250.00
MATTHEW PEARCE
Phone 02 9609 1101
Old 24-07-2007, 09:23 PM   #7
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Guns the same setup as mine wont fit under your SVO rims.
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
Back in a Ford XR. MA XR5 Mondeo
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2007, 11:06 PM   #8
Sprint347
Tickford
Sprint347's Avatar
interested in some info... i too would like good brakes under the sprint/svo wheels
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD
AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD
BA XT
SZ Territory TS RWD TDCi
Sprint347 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 02:08 AM   #9
halo
sorry to resurrect the thread but came across it and similar applies to me... I feel the breaks in my EA S are a bit on the weak side, could anyone recommend a decent package to me? Nothing too flash just for a bit more safety thats all i'm after..
halo is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 12:07 PM   #10
FLOORED
Race Brakes Sydney
FLOORED's Avatar
I could supply DBA slotted rotors front and back with some better street performance pads for around $850 or it can be done cheaper with different brands etc.
MATTHEW PEARCE
Phone 02 9609 1101
Old 22-01-2008, 01:38 AM   #11
halo
thanks but yeh 850 is a bit steep since the thing is only worth a couple grand.. i remember reading that the xr6s came with just the regular breaks is this true? if so i couldn't get some from the wreckers then and going aftermarket is a bit exxy for my likeing.. rims are 16" from an el xr6 if that helps re the clearance issue. thnaks for your help tho..
Old 22-01-2008, 01:42 AM   #12
atec77
Cheers Al
if you can find the right ones some of the Jag callipers fit so you can get two or 4 spots.
Old 15-10-2011, 01:15 PM   #13
mistermxer
mistermxer's Avatar
Default Re: Brake upgrade for an EA falcon
bendix ultimate brake pads, decent tyres, brake fluid change, nuff said
1991 EA Ford Falcon S-PACK 4 speed Auto. Current wheels (for the 2nd time...)
1990 Nissan Pintara Hatch GLi 5 speed Manual with extractors (the "second" car)
1991 EA Ford Falcon S-PACK 4 speed Auto (Dead on Arrival...)
mistermxer is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2014, 10:33 PM   #14
kgpp2293
Good Luck
So dig up an old thread but was it a straight fit for the calipers / rotors from the cobra mustang or was there excessive modification required ??
kgpp2293 is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2014, 03:19 PM   #15
FLOORED
Race Brakes Sydney
FLOORED's Avatar
All non E series calipers will require brackets and a modification to the upright.
These will also require a modification to the upright as they have protruding slides/lugs unlike most conventional cars that have 2 mounting holes.
MATTHEW PEARCE
Phone 02 9609 1101
