hi all i just wanted to no if i can fit a diff center from a ea to a ef and i have put some pics of my car on here aswell because im am kind of new to e-series even thoght this is my second one
LOW AND SLOW
Mate that matt blak XT Wagon is the most !!! I LOVE IT. Sorry if its not matt thats just my way. As for the diff i dont know as the wagon has me drooling.
"Any Color You Like As Long As It's Black, Matt Black, With Flames, And A Bit Of Pinstriping". Last edited by EAadam; 06-02-2007 at 10:47 PM. |
the thing you need to look at is the spline on the axle
early ea had 21 spline 2 pin lsd (if lsd)and late model ea (posiable from eb)-el had 28 sline 4 pin lsd im not sure on single spinner though hope this helps jason
#4 | |||
EA's have 25 spline, 2 pinion centres. It also depends on what ratio diff gears were fitted to the centre... Even if you could fit the centre, you would need to change the axles, and I dont think you can. The main difference with EF/EL to earlier models is the handbrake setup. The axles may be longer in the newer models to allow for the handbrake differences
Powered by Rollin Motorsport Turbo Barra ED 4L
#6 | |||
as for the diff its a lsd 3.25 ratio out of cop car or something like that i was told i could fit it to eds
so would the best thing to do be pull a axle out and count the spline
yea, count how many splines are on the axles...
also, does your ef have abs brakes
xc - my other love
if it is a 3.23, then the centers will be the same..
early EA had 2.92 - 25 spline lsd later ea and onwards have 3.08, 3.23 and 3.45 - 28 spline lsd if it is a 3.23, the it will bolt straight in. are you only bolting the centre in, or the gears as well?? if you are doing the entire diff, then you will have to jimmy around with the handbrake provisiion. my advice would be to change the centres, but don't bother until you find some better diff gears as well. you have a 3.08 at the moment, upgrading to 3.23 will do two parts of stuff all. look for a 3.89 or 3.92 diff out of an r32 skyline. they fit in falcon diffs and give far far far far..... far better accelleration. put that and any 28 spline lsd centre in your diff and you wont regret it. you can use your own axles with this setup too. total cost: 3.89 gears 50 bucks from a wrecker LSD - you have one already (make double sure its 28 spline tho) $400 MAX for diff bloke to slap it all together with new bearings. people will tell you to do it yourself, and use the shims that came with them blah blah blah... but dont. get a pro to do it. all housings and gears are different pending on wear. will cost you no more than $400 to do it, and you will have a diff that will last longer than you will oen the car.
Power = Money
How fa$t you wanna go?? apparently pretty fast - 400rwkw BF xr6t! FG F6 bottom end - GTX3582 - Nizpro 4" exhaust - Nizpro cooler - plazmaman intake - piping - plenum - batt relocation - injectors - surge &044 pump - valve work & valve springs - XCAL |
thanks heeps for help but i and im only buing this diff because its cheap and lsd and was reco not to long ago, and im only useing centre so it will do for now mabey down the track ill get a differant ratio
#12 | ||
If you are changing the crown wheel and it is a different ratio to the one you have you will have to change the pinion gear as well. Even if it is the same ratio i would be changing the pinion gear as the chances are is is worn slightly different to the other and you may get a diff whine.
The diff your refering to is 28spline. It was out of an ED Police car (opt20) on the tag. its of 3.27ratio.
go help everyone. Plus the diff was pulled out of the ed with 90,000km on the clock so id have about 120,000km on it now |
