4dlvr
any one got these rims on a au??? http://wheels.my105.com/index.asp?pr...6196&parentid=
is that a decent price or should i look else where? F*#k worng section, how can i change this to the au section??? |
#2 | ||||
![]() Join Date: Dec 2004
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
Just slidin'
I dont think Ive seen them on the AU. I think they would look fine.
MD Mondeo - For the family
#4 | ||||
BOSS Pilot
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
I'd seen that one before, that's the only one though. They look awesome. I think the ones on the white AU are 19's though maybe?
GT Killer
ebay i just got a set $970 shipped to my door
19's alittle over $1100 i think
BA XT 5.4Ltr Manual :thebirds: |
Just slidin'
I have seen that car, actually forgot about it. The only reason I know Ive seen it, is because I wanted to know what side skirts would look like without front and rears. What type of side skirts are they?
Hmmmm ... hotness ... would look great on the ute.
wonder if i can get 1-tonne rated tyres for them ... not that I need them. LOL 18"s would be good though ... 19" wouldn't handle decent weight for my application though. They look like SR skirts to me ... maybe BA SR skirts modified to kit ... agree about the skirts though ... they look neat indeed
Can get them in 17" as well.
Interesting.
They're the skirts that were standard on all series 3 AU's. They also came on some series 2 cars, I believe some XR's and the SR maybe...
#11 | |||
4dlvr
and thanks for moving it Kenaz |
#12 | ||
The side skirts look like stock Futura to me.
#13 | |||
#14 | |||
#15 | ||
Your car is a Classic though, so it's tarted up a bit. Like I said, only limited numbers of series 2's got them, but they were standard across the range on series 3's. Hence, if it were a Futura, and had those side skirts, it would have to be a series 3.
#16 | ||
Brembo Lover
They will be aftermarket clones though. They only came in 19" as genuine i believe. The BA mk1s were 18" but i different 7 spoke design (which im after for my fairlane actually
Mine: 2007 BFII XR6 Turbo in Conquer with Sunroof, BFII Typhoon rims, CarPC, FPV Leather Wheel Hers: 2006 BF Super Pursuit in Vixen |
#17 | ||
Tickford Equiped
So BA & AU are the same offset???
Genuine Tickford Equiped 1998 AU Fairmont Mods: ....... Dash mat & Air Freshener, does that count as a mod?????? Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System, |
#18 | |||
not here much anymore
RAM 1500
#19 | ||
T3/Sprint8
![]() Join Date: Jan 2005
I'm sure a Blueprint ute in the ftf club has them on ?
Check the au shownshine they look great imo....
#20 | |||
![]() Not an FTF member but apparently was at the ACT show and shine....
RAM 1500
#21 | ||
OLD SKOOL BABY
^^^^ Here you go mate.
Mick ![]()
XB Sedan - Trick Mansweto built 351 3V Alloy Headed Cleveland,Demon Carby ontop of CHI Hi Rise Manifold - 600HP 83 F100 XLT - 351 Cleveland C6 Auto wrapped in Black snake skin vinyl, daily tow rig.![]() 1976 XB GS COUPE (waiting to start the rebuild)
#22 | ||
T3/Sprint8
Well done fellas, there you go !
I really like them but sadly not wide enough at the rear imo....
#23 | |||
#24 | |||
Brembo Lover
In the FPVs, apparently the rears are a different offset to the fronts and will cause issues in the future. If i get them from FTG, the rears are going to be different. If i get them from WK, all four are the same offset (ie: front) as they need to be for AU.
#25 | ||
I am not a tire professional, but from my experience at putting these ORIGINAL FPV rims (before the copies we released) on my AUIII Futura - Ford asked 4k for the set with rubber and the rims stuck out by approx. inch and a half at the front.
BA and AU offsets ARE NOT the same - Especially FPVs... GT and GTP offsets are different front and rear... Copies however state if they fit pre BA / AU, etc... My advise would be to double, triple check the offset and check with a very helpful guro that knows what he's on about like Turbo Nick - Or search the Wheels and tires section! Check out the Mag stores on Ebay... Bargains galore now! Hope that helps! |
#26 | |||
Brembo Lover
So what probably happened is you got 4 rims that were of the REAR offset. If you got 4 rims with front offset, they would fit perfectly.
#27 | ||
Capri GT/TS50/GTR
hmm this intresting because i have been looking for a set of f6 18's (still havent found any :( )
anyone know if the copies are heavier then the fpv ones |
#28 | |||
Brembo Lover
#29 | ||
OK, sorry to resurrect a dinosaur of a thread, but might as well instead of starting a new one...
My question is, will genuine FPV 18" GT wheels with the different offset front to back, fit an AU Fairmont (non-IRS). I presumed they would, since the T series had different offset on the rear (28.5 IIRC), but they were IRS weren't they, and I read somewhere the FPV utes had the front offset (ie same as AU offset) all round since they were live axle. Is there another reason for the utes having the fronts all round? Since it's only about 8mm I think it would be OK, they'll just sit that much further out, but someone who's done it before's advice would be appreciated, to reassure me they won't hit anything etc. Thanks very much! |
#30 | |||
http://www.wheelking.com.au/Wheels/t...9/Default.aspx or ebay has heaps http://search.ebay.com.au/search/sea...eels&category0= ------------ |
