Old 06-01-2007, 04:03 AM   #1
willygrice
Default Falcon Brakes? Falcon Diff? On a MK2 Escort
I have heard of people putting Falcon disc breaks on Escorts, is this front or back or both? Is this a bolt on mod? Can a Falcon diff be put on an Escort or is that to difficult or too wide?
willygrice is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2007, 05:12 AM   #2
JamesR
certain hilux diffs bolt straight in. [with a little work]
and you can get brake kits for the front. see hopper stoppers
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2007, 05:35 PM   #3
Jim5_0
I have Falcon brakes on my Capri using the CRS kit (same kit Capri or Escort) You have to get the falcon hubs machined to fit on the shorter stub axle.
I have a narrowed Falcon diff in the rear to match.
Jim5_0 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2007, 07:05 PM   #4
mk2maniac
Anything will fit with a degree of work. Don't be looking for something that will just bolt in, as often the best option is to custom make something, or modify an existing part to fit. The easy way will only come back to bite you in the ar$e. And it seems from your recent threads that that's the option you are trying to take, willygrice. Not criticising you, just trying to offer some advice.
mk2maniac is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2007, 06:34 AM   #5
cortina-mk1
Heavy right foot
cortina-mk1's Avatar
hoppers stoppers brakes kits are a bolt on kit
they are by far the easiest and versaile option to upgrade your brakes
any diff you are fitting like what you speak off will require narrowing
for your application i would consider a borg warner like from a commodre fitted with 4 pinion LSD
then your rear brakes will be sorted also
only needing a master cylinder upgrade
cortina-mk1 is offline   Reply With Quote Multi-Quote with this Post
