Old 10-11-2006, 05:24 PM   #1
poolkeeper
Its Resonating!
poolkeeper's Avatar
Default Replacing Fuel Filter
Is it just a matter of getting the fuel out, undoing the filter and taking it off, then just whack the new one on?
Thanks...
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2006, 05:26 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
just a matter of undoing the lines and swapping it over quick and avoid getting fuel on yourself, I like to turn the key to the on then off positon a few times to re-prime the fuel line, then start it and make sure no leaks, all good.
Old 10-11-2006, 05:51 PM   #3
mattp
mattp's Avatar
Take out the fuel pump fuse, then turn the engine over a few times to get the fuel out of the line, then go for it.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2006, 07:48 PM   #4
Futura01
horsepower
i learnt the hard way and had to buy a new hose cause the rubber hose attached to the top of the fuel filter needs the thumb clips to be pressed in quite hard(ford use a tool to do it) then it will pop off smoothly.
Futura01 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2006, 08:21 PM   #5
Tickford Kid
Formerly known as TS 50
Tickford Kid's Avatar
I think AU's have two types of fuel filters. Non IRS and IRS types. Great fun to change aswell. Hope you like the smell of petrol!
BLUEPRINT T3 TS50 #109, MANUAL WITH BREMBOS
Tickford Kid is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2006, 10:36 AM   #6
str02
99 AU Futura
str02's Avatar
There are a couple of recent threads covering this, search will find them, I did mine recently and it is a PIA
I am not young enough to know everything
str02 is offline   Reply With Quote Multi-Quote with this Post
