Resident Nyctophobic!!
Which au's got LSD's?
Did the AU3 XL SE utes get them? |
this may help, http://www.fordforums.com.au/photos/...cat=669&page=1
Flat floor shifter
I had to option one on my series 3 xr8 ute when l brought it new so l highly doubt it would be std on an xl se unless the owner optioned it also.
on second thought, stick your head under the back of it and have a look on the diff...if it's lsd they usually have either a stamp or sticker saying lsd on them
TL40 Wagon?
I always say if you have to ask you haven't got one.
I knew my dif wasn't but i wasn't sure if it was an option or not, thanks for clearing that up guys.
is there a thread somewhereon the pros and cons of an LSD? |
I'm not sure on a thread, put a pro of it is no more one wheeled burnouts lol
Its gone V
Its all pros, i put one in my car because being manual, it just wanted to spin the one tyre if you were tring to pull out into a small gap in traffic or u-turns etc... thats probly the only sensible pro to an LSD, but is very helpful.
Id say the only con is the price. |
what does one in good nick go for?
or even new price? |
#10 | |||
Highway Taxi
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
#11 | |||
#12 | ||
I found the car I had with LSD wore the rear rubber a bit quicker. And no it was not doing burnouts!
If you are driving in slippery conditions alot ... and LSD could be a little dangerous though ... Orbit it just depends on your driving ... but i guess on some dirty roads it could be a bit hairy (but that comes down to your right foot too) .... and it could be fun as well ... LOL.
I have found when loaded up in the wet ... especially on corners ... or turning out of intersections ... a single-spinner has saved me a few times (especially in traffic).
#14 | ||
Thanks mechanik.
I do drive in slippery conditions alot...but i've driven other cars with LSD's in the same conditions with out too much drama. No doubt you hve to adjust your driving style a little, but i think there are some definate benefits. I'll have to have a bit more a of a think and get some prices. |
#15 | |||
from what i understand that's how it works anyway |
#16 | ||
no bodes-sh.. when turning corners they both wheels dont turn the same speed.. it works just like a diff... thats why its called a differential... the inside wheel is meant to spin less so cornering is made easier.. the situation u are describing is it a welded diff or spool.. where both spin the same.
LSD's are limited slip...they are designed to stop wheel spin. they dont create it. its just that when they are hammered around corners and the wheels spin, both spin at the same rate.
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
#17 | ||
bodes: I know how a diff works and you are half right. As Baboon said it doesn't lock the wheels straight away, it only locks them once one wheel is spinning a certain amount more than the other
It will lock them on tight corners, u-turns etc hence yes the rears wear out quicker They are much safer that's for sure, it's a bit harder to break traction and if one wheel does lose traction then the other one will grab, that's a pro Another con is that losers leave 2 marks on the corner by my house instead of 1. |
