11-10-2006, 01:35 PM | #1 | ||
I Have just fitted a AU2 Dash into My Dodge truck and need to wire up the lights onto the Au switch but can not work out the AU wiring can some one please let me know what is what Have checked the diagrams but can not work it out.
There is 1 thick Black 1 Blue/Black 1 1 Black with silver dots 1 Red/Blue 1 white 1 White/Black and 1 Red/Yellow Please help ASAP and send to samrex@hotmail.com Thanks |
11-10-2006, 02:38 PM | #2 | ||
Will swap info if you post up a pic of the AU dash in the dodge truck.
The headlight wiring goes to the BEM, then to the lights. You will need to follow the diagrams on the attached link: http://www.fordforums.com.au/photos/...7&page=1&sort=
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, HSD/ShockWorks, black GT335 19” staggered replicas with 245 & 275/35/19 Michelin Pilot sport 5s Daily: BF2 Fairmont Ghia I6 ZF, machine face GT335 19” staggered Replicas with 245s and 275s, Bilsteins & Kings FPV 335 build stats: <click here> Ford Performance Club ACT Last edited by JC; 11-10-2006 at 02:50 PM. |
11-10-2006, 03:57 PM | #3 | ||
Thanks for the reply and will get pics soon just want to get this settled 1st.
I am using the original AU wiring for the switch but need to connect my switch wiring to this and have no idea which wire goes where!! I have tried to work this out but can not. Is there any way you or any one can let me know which colour from the switch is what?? Thanks |
11-10-2006, 08:35 PM | #4 | ||
The wiring diagram I have all shows wires feeding into the BEM, but from what I can work out:
1 thick Black - earth 1 White/Black - goes to fuse box, so would be power source. 1 Red/Yellow - goes to column switch which controls high beam on or off (see note below). 1 Red/Blue - could this be purple/orange (Purple/Orange is park lamps) 1 Blue/Black - Goes to door marker lamps (part of interior lighting) 1 Black with silver dots - (could this be grey/black?) gry/blk goes to other side of dome lamp 1 white - (could this be grey?) grey goes to domelamp (interior light) Note - The Red/Yellow wire ends up going through a high beam switch and then out to a high beam relay and a low beam relay - looks complicated. Hope this helps.
11-10-2006, 10:17 PM | #5 | ||
Well I have destroyed the switch by burning it out from incorrec wiring.
If someone could please get back to me with the right wiring colours and what they go to it would be great.. The above is hlepful but I need to be exact as I do not have access to these light switches Thanks |
11-10-2006, 10:39 PM | #6 | ||
Chairman & Administrator
HERE is a link to the colour code sheet for the AU wiring. If you loom a little deeper through the wiring diagrams you will see the connector (by number) for the plug that will have the codes and pin assignments.
Cheers Russ
Observatio Facta Rotae
11-10-2006, 10:58 PM | #7 | ||
Guys thanks for the trying to help and I do appreciate it but I simplu need to know where each colour comming of the connector from the lights switch goes??
Which one is constant power? Which is earth?? Which is head lights/Park lights/Dash lights and which is dimmer?????? Thanks again |
11-10-2006, 11:55 PM | #8 | ||
I've enlarged the relevant sections of the diagrams below:
From what I can see... Black = Ground Y = Power from a 60A fuse via a smaller in-line fuse V/O = BEM - not required in this instance. W = Cluster dimming circuit W/Bk = Park Lamp Relay R/Y = Column switch on the active side (headlamp flash) Bk/Db = Courtesy illumination circuit Db/R = ditto R/W = ditto Cheers Russ
