07-09-2007, 11:22 AM | #1 | ||
14.915 @ 151 KPH
hey guys, just wondering how long have you had your current car and what problems have you had with it? also how many k's has it done? ill start with mine:
Model: 95 EF Auto I6 Km's on it when bought: 280,000km Km's now: 320,000km Owned it for?: 18mths Probelms encountered? Manifold Gasket = $250, Oil Pressure Switch = $50, Bottom Radiator Hose and Heatertap = $100 (all the above included labour at my mechanic and oil/coolant) : Thats right folks ive only had minor things go wrong (touch wood) for the total some of $400 and apart from the rough idle i have (cleaned throttle body/and that idle valve thing, didnt fix so gave up) it runs like a clock and hasnt given me any trouble!
:evil3: 96 EF2 Futura I6 Auto :evil3: EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's : , XR6T Snorkle/Fram Filter, 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD, 5% Tint, Sony Head Unit/ 6 1/2 Inch 190w Speaker's : 14.915 @ 151 kph 60' 2.254 : |
07-09-2007, 11:32 AM | #2 | ||
94 ed auto I6
orig km 227 km now 240 owned 8 months problems:nothing i didnt cause |
07-09-2007, 07:38 PM | #3 | ||
Gunna girlie-man
92 eb2 manual i6
orig km- 289,000 now- 335,000 owned- 9 months problems- Oil rings, gearbox synchro's, electrics(my fault)
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done |
07-09-2007, 07:44 PM | #4 | ||
Parts bin special
Model: 90 EAII Fairmont Ghia
Km's on it when bought: 148,000km Km's now: 250,000km Owned it for?: 5 yrs, 6 months Problems encountered? Head gasket, bands in auto stuffed, fuel pump, air con compressor, 2 power window motor/regulators, fan speed controller, idler pulley (my fault), steering rack, thermostat, 2 heater taps, cracked coil, weird issue with SLS suspension which caused it to raise to maximum height, ball joints stuffed, suspension bushes, steering rack mounts are currently pretty sloppy, and the rear trailing arms need replacing These are the main ones. Most are just general wear and tear.
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
07-09-2007, 07:47 PM | #5 | ||
Gunna girlie-man
07-09-2007, 07:48 PM | #6 | |||
Parts bin special
07-09-2007, 07:51 PM | #7 | ||
Gunna girlie-man
my last car
89 ea 's' pack manual orig k's- 320,000 (when it died) 389,000 owned 14 months probs- Head gasket (2), clutch, diff (2), trailing arms, ball joints, seized brake calipers, dead handbrake, heater tap, lpg backfiring.
07-09-2007, 07:56 PM | #8 | ||
1989 EA FAIRMONT GHIA
Owned it for a year 212.000 Probs: 2 window regulaters and a windscreen |
07-09-2007, 08:03 PM | #9 | ||
Model: 94 EF Fairmont Giha
Km's on it when bought: 203 000 Km's now: 208 000 Owned it for?: 2 months Probelms encountered? Auto has a crack in it and leaking out fluid over the exhaust (Have a LE97 out of the XG it put in it done 20 000k's) Exhaust falling off (Took the tune lenths off the XG) Intake manifold gasket Crook injector (I have my own injector test bench and cleaner) thermos stuck on cd player catching on fire (it was a crap radio anyways) have a little bit of back lash in the diff (dont care) front suspention bushers front sway bar bent (i have know idea on that one) coil pack dieing Last edited by xgme; 07-09-2007 at 08:09 PM. |
07-09-2007, 08:11 PM | #10 | ||
AU II XR8
1988 EA SPAC manual, LSD
ks when bought 148,000 current Ks 170,081 50% blocked radiator, overheates in 45 deg wether, coolent level senser quit its job, aircon leak that i still havent fixed, many suspension problems that still exist.
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
07-09-2007, 08:19 PM | #11 | ||
XR6 Turbo FTW
cruiser
Model: 95 DF2 LTD Auto V8 Km's on it when bought: 139,000km Km's now: 195,0000 Owned it for?: 21 mths Probelms encountered? auto problems, too smooth for lowered lol Daily Model: 93 EB2 manual I6 Km's on it when bought: 118,000km Km's now: 145,0000 Owned it for?: 10 mths Probelms encountered? faultless really reliable car
02 BA XR6 T U R B O - 232rwkw @ 6psi Blueprint, 19" FG2 XR6 Luxo Rims, Momo Steering Wheel, XR8 Bonnet Buldge, Full Leather, 3.7 Typhoon Diff Gears, Force Lip Spoiler, De-badged, Ghia Boot Garnish, Pedders Adjustable Coil- Overs And Camber Kit 96 EL XR6 - (Daily) Gunmetal Grey, 19" Typhoon Copies, Tickford Body Kit, Pedders Sports Ryders With Shortened Shocks And Camber Kit, Full S/S Difilipo Exhaust With Matching Extractors |
08-09-2007, 02:31 PM | #12 | ||
i have a 93 eb2 5speed
it has 270 000 on the clock though the engine has bee rebuild about a 100 000ks ago before i got it. problems i had with it coroded rotor button and dizzy cap.... problem im having with it at the moment is it surges and hops like a kangaroo on deceleration and low revs. am yet to find out what the farrrrk it is. helllllllllllp! |
08-09-2007, 04:08 PM | #13 | |||
14.915 @ 151 KPH
08-09-2007, 04:48 PM | #14 | |||
AU II XR8
08-09-2007, 04:54 PM | #15 | ||
14.915 @ 151 KPH
lol ok!
08-09-2007, 09:01 PM | #16 | ||
low wagooon
Model: 96 S2 GLI Wagon
Km's on it when bought: 328,000 Km's now: 330,000 Owned it for?: 6 months Probelms encountered? None while ive owned it. Previous owner replaced fuel pump thats it
Webby
S2 AU XR6 UTE |
