Old 13-08-2006, 12:07 PM   #1
crossingover
crossingover's Avatar
Default front hubs
just pulled off my discs to my shock i need a 35 mm socket for hubs bearing nut have basically looked all over around autobarn repco no one has it any ideas guys can i rent one im stuck
crossingover is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2006, 02:43 PM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
If you know someone who owns a bulldozer/grater/or other large machinery vehicles, then you could ask them if you could borrow their socket set, they use sockets aound this size , maybe even try like one of those places that hire out large machinery / it wouldn't suprise me if they hire out the socket sets too .
Also Fitting and Turning suppliers sell sockets that large (alot of bolts are around 35mm that hold the press tools into the 200 tonne presses and larger ).
Or your favourite mechanic might lend or loan you his if you know them well enough. lol
Oh , i have also seen them in supercheap auto in the past , them might still have them in stock.
By the way , it won't be cheap to buy a socket that large ! . gl , cheers.
:eclipsee_
Old 13-08-2006, 03:18 PM   #3
Baboon_AU
Baboon_AU's Avatar
a 35 mm socket comes in a 3/4 set.. i have a 3/4 set for work as i am a mechanic for CAT. most of my sockets are rather large.. go to bunnings.. the have 3/4 gear cheap
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2006, 06:43 PM   #4
AU-MUSTD
Flat floor shifter
AU-MUSTD's Avatar
I found this out the other week and bunnings didnt have any. Can you get them in 1/2 inch???
AU-MUSTD is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2006, 07:15 PM   #5
Baboon_AU
Baboon_AU's Avatar
no. no one will make a 35 mm socket in half inch. that comes under 3/4 gear
Old 13-08-2006, 07:57 PM   #6
XR6-VCT-2000
Fantastic Plastic
alot of the 3/4 sets i have seen don't even have a 35mm in them , alot of them go straight from 34mm to 36mm (not all of them though !), although you would probably find you could use a 36mm socket (1mm larger) on a nut that large a size np without causing any damage to the nut.
:eclipsee_
Old 13-08-2006, 08:00 PM   #7
EvilChief
Boost Addict
finding a socket is one thing, dinding a ratlle gun with enough torque to pull it off and put i back on is the other.
last time i changed my front bearings we had to use a 1000Nm rattle gun ... damn that was fun .. NOT
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 13-08-2006, 08:03 PM   #8
XR6-VCT-2000
Fantastic Plastic
lol , to me a rattle gun wouldn't even come to mind when undoing a nut this size ! , i would have a 1.5 to 2 meter length of steel bar hanging off the main bar attatched to the socket , for the leverage ..lol
:eclipsee_
Old 13-08-2006, 08:15 PM   #9
AU1XLS
AU1XLS's Avatar
useless without pics
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2006, 08:24 PM   #10
EvilChief
Boost Addict
that was useless to us, we had the entire upright assembly removed from the car as we swapped from s1 to s2
N12 Pulsar - sold
Old 13-08-2006, 08:26 PM   #11
cookie
BEER I NEED BEER
cookie's Avatar
yep thats what i did when i changed one of mine about a month ago
worked hard to get my new beast and i love it, it rocks. MYR16 the beast
cookie is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2006, 08:37 PM   #12
AU-Hog
AU-Hog's Avatar
Total Tools in Ferntree Gully have 1/2in drive 35mm sockets etc. I bought one there about 4 months ago to replace the front hub on my AU3.
If the car is supported properly and you have a strong arm, a 12" bar should be enough to loosen the nut if you are careful.
Use a torque wrench to tighten the nut again afterwards so the correct tension is applied to the bearings.
See the following for more info.
http://www.fordforums.com.au/showthread.php?t=48203
Andrew
PXII Ranger Single Cab tray
SYII Territory
AU-Hog is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2006, 08:40 PM   #13
XR6-VCT-2000
Fantastic Plastic
np, ok then , like so ;) ..cheers .
allthough this is not my car or picture ! , but i wouldn't recomend using a ratchet , use the solid bar conector , good chance of breaking your ratchet using it like this !
:eclipsee_
Old 13-08-2006, 08:47 PM   #14
crossingover
thanx for info guys i ended up taking hub assembly to my mechanic and he leant me his tools and torque wrench must admit was preety hard to remove it
