Old 13-07-2006, 06:58 PM   #1
berzerker
Default Ford Telstar GHIA 2.5 V6 idling high
Got my car back from the mechanics today (needed new clutch), noticed its idling a bit high about 1100rpm, tried the obvious to get it down to about 800, and it wouldnt drop.
Is there any trick to the v6? what am i missing?
berzerker is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2006, 11:56 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default intresting problem
taking the gearbox out and changing a clutch
they shouldn't have touched the idle to do that work
if that is an EFI
wonder if the Throttle position sensor isnt out or the air meter
the idle adjustment screw should have done the job
timing ?
to hard to diagnose without more information
best take it back to the mechanic that did the clutch
My car goes Brumm Brumm
Old 14-07-2006, 04:37 PM   #3
berzerker
two questions
where is the
Throttle position sensor located &
where is the
air meter sensor located?
I have spoken to the mechanic and hes fine for me to take it back, problem is with work and family functions i wont have the chance untill monday, will this cause any damage?
Old 14-07-2006, 09:09 PM   #4
dirty hands
Over Thinker
no wont do any damage just use up fuel a bit
Have you slackened off the throttle cable ?
I still dont know why the idle adjustment screw isnt working
I will send you a picture of the engine see if it is of any help to you
two questions -both need a volt meter to check if it is working
Throttle position sensor - on the throttle body with wires
air meter sensor located-inside the air filter usually
wait till the mechanic looks at it on monday
Old 14-07-2006, 09:48 PM   #5
berzerker
mechanic is looking at it 2morrow, so ill update this thread.
Only thing i can think off is the cat converter had to be replaced because the other one was in pretty poor condition, perhaps the sensor wasnt hooked back up?
Will have a little fiddle with it 2morrow morning but ill probrobly just leave it to the pro's
Old 14-07-2006, 10:37 PM   #6
dirty hands
Over Thinker
undo the battery terminals for 10 minutes then reconnect
that resets the computers
if it still revs high then something needs to be checked or replaced
I would have renewed the 0xygen sensor if they did the cat convertor
