Old 07-07-2006, 02:59 PM   #1
Mudbash Escort
Default Hilux diff in esky?
hi guys,
ive been reading, and have read some stuff regarding hilux rear diff, geting put in an esky...
so is it hard to do, as some are lsd's and have a high ratio, which will be good for motorkhanas etc..???
thanks mike
Mudbash Escort is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 08:18 PM   #2
eski666
eski666's Avatar
Im waiting to put mine in havent had the time yet. The early ones are just about the same length and almost bolt straight in.
eski666 is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 08:33 PM   #3
V8falcons
V8falcons's Avatar
yeh they do fit you need an early model hilux to get the right width which are getting hard to find. or buy a mazda/ford courier series 1 diff semi floating set up., correct width + 5mm over all, correct spring seats, just wheel PCDs need changing back to escort.machine shop job very easy
got one out the back ready to go in my RS and you can get LSD centre ,so Im told.and a good range of gears for them
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2006, 01:38 PM   #4
eski666
eski666's Avatar
any one know about the lsd centres if they all are the same? Saw one on ebay but was out of a later model one. My diff is a 75 model i think and wouldnt mind putting a lsd in it rather than welding the thing up.
