Old 15-05-2006, 02:31 PM   #1
Dano
Default help! gutless 2l pinto
Hey,
I have a 2door, 1980, 2litre, escort, manual
Basically it goes like crap, I have been in stock 1200 corolla that goes harder.
There are a few things going on:
1. It pings its head off at more than half throttle (I think I can fix this by adjusting the timing)
2. When I start it in the morning, even with a brand new battery it struggles to turn over, It sounds like it's half seized or something
3. It sounds like a tractor when its idling even after fitting a brand new muffler and an extra baffle.
Apart from fiddling with the timing (it is now set to specs from gregorys manual) What should I do?
Dano is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2006, 04:47 PM   #2
shepv8
V8's for ever
Check points dwell angle, cylinder compression , spark plugs and leads, and get the weber carb serviced by a decent tuning shop
shepv8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2006, 04:49 PM   #3
EA2BA
PM me if you want
EA2BA's Avatar
get a kit and service the carb yourself it is really not difficult at all.
Sounding like a tractor, 1. check your manifold exhaust manifold bolts are tight, 2. check the timing sounds lik,e it running very retarted timing or its way off.
Old 15-05-2006, 04:50 PM   #4
shepv8
V8's for ever
oh , your starter motor could need a look at. Check the brushes etc.
if it sounds like a tractor check you dont have a leak at your exhaust manifold. If unsure put a new gasket in and torque up the exhaust bolts properly
Old 16-05-2006, 12:24 AM   #5
tufLTD
tufLTD
tufLTD's Avatar
Originally Posted by Dano
Hey,
Sounds like your timing is way advanced. This would cause the pinging & the sluggish starting. Try setting the timing to 10 deg BTDC at idle (with vacuum hoses disconnected). If it doesn't ping at 10 deg, try going up another 2 deg at a time until it pings, then pull the timing back a little.
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2006, 12:25 PM   #6
Dano
cheers dudes, im onto it. will let u know how i go
