Old 15-04-2006, 03:56 AM   #1
FRDGAL
GT-P #0336
FRDGAL's Avatar
Default AU brake upgrade choices?
Hi guys
Just after some suggestions. I'd like to upgrade the AU's stopping power. I've got Series1 brakes. What are my choices? Also interested in what people's preference's are when it comes to brake pads?
Krissy
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST
~Tuned By Bluepower Racing~
FRDGAL is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2006, 04:09 AM   #2
GK
Walking with God
GK's Avatar
Originally Posted by FRDGAL_AU6
Hi guys
Krissy
My understanding from seeing much here is that unless you're doing lots of full on driving (track) then DBA slotted rotors and Bendix Advance pads are a great improvement over stock. I'm pretty sure apart from pads, that Casper has this set up, as will many.
Hightek Brakes - Factory 11, 59-65 Keys Road, Moorabbin, 95531160.
If you check a thread I started "Slotted Rotors" there is a link to Hightek Brakes who were having specials $100 per disc up until Easter. Casper thought pads would be round $80, so $280 all up if you were handy enough to install them! I would like this setup myself, should ring Hightek later today and see if they have any left! Could get them on in time for the BBQ!
Hope that helps Krissy! BTW it took me a while to pick up that you had changed your name!! Your car is looking good, hope you are happy with it!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 15-04-2006, 04:27 AM   #3
carratt
I Love My T3
carratt's Avatar
yep, DBA slotted rotors and Bendix Advance pads is the same setup that I fitted to my car about a month ago and I was very pleased with the results.
A slipping gear could let your M203 grenade launcher fire when you least expect it. That would make you quite unpopular in what's left of your unit. - the Army's magazine of preventive maintenance.
carratt is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2006, 04:35 AM   #4
FRDGAL
GT-P #0336
FRDGAL's Avatar
Hey George Hey Brad
Are Bendix dusty? I don't know what mine are but they're very dusty.
Old 15-04-2006, 04:42 AM   #5
carratt
I Love My T3
carratt's Avatar
hey krissy
nah, they aren't that bad. The bendix ultimates that I had on there with the stock rotors were heaps worese than the advance with dba slotteds.
Old 15-04-2006, 08:06 AM   #6
EvilChief
Boost Addict
S1s are rather limited in their stopping power. only "upgrades", more like replacement options, are a set of slottered, cross drilled or dimpled rotors with some good pads.
DBA has the slottered and cross drilled gold series on option, whereas RDA has also the slottered and the slottered & dimpled rotors. All o fthose rotors are around the $100 mark ea depending on how u well know the people at the shops.
As for pads, there are more options than fingers on both hands. Personally i have used Bendix ultimates and RDAs own "sports" pads and both are just working fine for me on street use. So just go for personal preference.
Having said that, if you are more serious about an actual brake upgrade as such, might wanna consider a S2 front suspension change, which involves changing uprights, lower control arm, swaybar, swaybar links and various little things.
With the S2 setup you now can easily bolt on the Tickford/PBR twin piston premium caliper or AP Racing or Brembo 4 piston calipers with the enlarged 330mm rotor.
Just a heads up
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 15-04-2006, 08:47 AM   #7
The Monty
Just slidin'
The Monty's Avatar
As has been said, DBA slotteds, and Bendix pads. I find the pads a little dusty, but my car gets cleaned every weekend, so it doesnt matter. They pull up well, nice and smooth, and are a lot better than the originals. I dont think you really need to spend the extra on cross drilled, unless you do a lot of track work. Just my opinion, hope it helps.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 15-04-2006, 08:48 AM   #8
Bucknaked
Bucknaked's Avatar
I've got the Premium brake package on the XR6. Same ones that Evil Chief mentions. You should contact FTG. They have just had a Pursuit come in and it will have those calipers. They should give you what you need to stop all your G&D mods :
If they are too expensive, i'd look at some PBR's. The tickford Calipers are PBR's anyway. If you get the tickford ones, make sure you order a refurbishment kit from John & Cebco. The pins wear out an you get movement in the caliper. There is to be a thread around which talked about these pins
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Old 15-04-2006, 09:29 AM   #9
EvilChief
Boost Addict
monty: cross drilled + track racing = bad, seen too many crack under the extreme heat, and also i have seen some pretty bad brake dust build up in the drill hohles after racing. would recommend the 4x4 wiper slot rotor instead
N12 Pulsar - sold
Old 15-04-2006, 10:31 AM   #10
Casper
Contributing Member
Casper's Avatar
I'll just clear up that I do have DBA slotted rotors but I dont (and would never use) Bendix pads. I find them to be inferior. I have currently been running Ferodo Formula pads.
Older, wiser, poorer.
Old 15-04-2006, 10:36 AM   #11
The Monty
Just slidin'
The Monty's Avatar
My bad. I just thought that was the case. I also thought it would be a waste of money (if your not after the nice looks of them) buying cross drilled rotors for the street. I use plain slotted, and they work wonderfully.
Old 15-04-2006, 10:39 AM   #12
EvilChief
Boost Addict
yer same
i have cross drilled on the rear for **** factor, na funnily enough i got the rear CD rotors cheaper the SL rotors.
N12 Pulsar - sold
Old 15-04-2006, 11:03 AM   #13
The Monty
Just slidin'
The Monty's Avatar
Lucky bugger :king:
Old 15-04-2006, 11:19 AM   #14
loxxr6
XB in parts...
loxxr6's Avatar
How much do you want to spend ?
www.cebcobrakes.com.au >> www.cebcobrakes.com.au/files/uploads/FAL116.XLS
Old 15-04-2006, 11:38 AM   #15
SirHenry
Falcon Unbelievable!
I just had my brakes done not so long ago and had them fitted with some
Lucas pads.... yes these will get a bit a dusty but all pads do owing to non-asbestos regs but so far I have not had these babies squeal once, they're fantastic.
Personally I would not hesitate to recommend Lucas, they aren't one of the market leaders for nothing.
Chris
SirHenry is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2006, 11:45 AM   #16
GK
Walking with God
GK's Avatar
Originally Posted by loxxr6
I wouldn't be spending 2.6k, not sure what Krissy is thinking though. LOl!
As well as the Easter special at Hightek, DBA slotteds can be had roughly from Brakes Plus for $100. I will need to confirm this though as the store mananger was on holiday until Tuesday, the call was tranferred! At least he's keen for business I guess LOL!
GK
Now gone!
On LPG
Old 15-04-2006, 11:58 AM   #17
xr8ute
Back on the road
xr8ute's Avatar
I dont rate Bendix at all...
They Bendix Ultimates that where on my car when I bought it where only marginally better than the $30 "Powermax" pads of got on my car at the moment.
There are a few guys who have used Formula Ferodos (TS2000 compound), and all agree they are brilliant. There a also a couple who have rated the QFM (A1M compound) very highly as well.
Old 15-04-2006, 11:58 AM   #18
jonbays
TL40 Wagon?
A wrecking yard SII upgrade will do all you need for a raod car.
Try FTG our sponsors
Old 15-04-2006, 12:01 PM   #19
JC
JC's Avatar
Got slotted DBAs and Bendix Ultimates on all four wheels on my series 1 XR8, and it pulls up as well as the Series 2 wagon with the twin spot calipers and DBA slotteds at the front. Funny how an upgrade on a series one matches stock on a series 2. The slotted rotors + Advance/Ferodo pads are a huge improvement over stock on the series 1s.
Ford Performance Club ACT
Old 15-04-2006, 12:09 PM   #20
GK
Walking with God
GK's Avatar
JC, so you're happy with your Bendix pads obviously!
What are your thoughts on Caspers comment that Ferodo are heaps better?
Actually Casper, could you unpack that comment for me a little?
GK
Now gone!
On LPG
Old 15-04-2006, 12:22 PM   #21
Whoosha
AU DIE HARD
Whoosha's Avatar
Hi guys
Krissy
Gee krissy you don"t want to say that to loud on wednessday or you"ll get the "GEE DIDN"T YA KNOW WE HAVE A BRAKE UPGRADE FOR YOU TALK " from you no who :
Originally Posted by Riksta
Old 15-04-2006, 02:13 PM   #22
loxxr6
XB in parts...
loxxr6's Avatar
Anyone here know a rough cost on what this would be worth to do ?
Old 15-04-2006, 02:14 PM   #23
loxxr6
XB in parts...
loxxr6's Avatar
I have Bendix pads and I haven't had any drama's with them. My car's pulled up a few times in emergencies and has been fine.
Old 15-04-2006, 02:40 PM   #24
Bucknaked
Bucknaked's Avatar
Get one of those hooks they put on aircraft to land on carriers. You'll stop real quick with one of those
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Old 15-04-2006, 02:52 PM   #25
stiddy
stiddy's Avatar
Ive got slotted rotors, and bendix performer pads.. and ew, the brake dust is the worst thing ever, just finish cleaning the chromies and even if you dont drive the car they get covered in brake dust, thats how bad they are lol. the rotors and pads helped stopping by 20% atleast, BUT when the pads start to wear out, they arent anything special.. Im not happy with them.
Id stay away from bendix pads, but definately get slotted rotors. Or speak to FTG and get a premium brake upgrade package from one of the wrecks.
Old 15-04-2006, 02:52 PM   #26
Casper
Contributing Member
Casper's Avatar
GK
I have run Bendix in the past but the last lot were not like they used to be. I dont think they ever got the asbestos free formula quite right. Just my opinion and I prefer Ferodo's now. Plenty will disagree and thats their choice. Either way boths types of pads and slotted rotors will pull up far better than stock. I just have a preference for Ferodo Formulas.
Old 15-04-2006, 02:54 PM   #27
Bucknaked
Bucknaked's Avatar
I use Ferodo too for the record. They are as dusty as anything, but it just gives me more quality time with my car cleaning the wheels. They stop better too. So its a win win situation for both me and my car. : :eclipsee_
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Old 15-04-2006, 03:26 PM   #28
JC
JC's Avatar
Performax are a good track pad, but no good for the street. They require a lot of heat into them before they are really effective, so that's where the Advance come in - great for the street in terms of both dust minimisation and stopping power, but I cooked a set at Wakefiled after only 12 laps (2 lots of 6).
I have never used Ferodo Formula pads, but will look for them next time I need to change brake pads. That way I can see for myself if they are as good as everyone says they are.
Old 15-04-2006, 03:30 PM   #29
Casper
Contributing Member
Casper's Avatar
Good but DAMN, dusty as all hell!
Old 15-04-2006, 03:34 PM   #30
JC
JC's Avatar
In that case, I may stick with the Advance - GOOD, and not as dusty.
