Old 15-03-2006, 01:43 PM   #1
Aussie_Escort
Aussie_Escort's Avatar
Default Super Noob Question
Hey guys,
Are all 2L engine's out of escort/cortina pinto's?
If not how do identify a pinto engine?
SORRY GUYS!
Aussie_Escort is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 04:10 PM   #2
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Just about. You can see the pinto engine is an OHC engine, it has a pressed tin cover over the drive belt/cog at the front that is quite distinctive and is a lot taller than the alternate non-ohc crossflow Kent engine.
Old 16-03-2006, 05:56 PM   #3
tufLTD
tufLTD
tufLTD's Avatar
Originally Posted by Aussie_Escort
Hey guys,
SORRY GUYS!
I think 'Pinto' is American terminology that's been accepted world-wide.
Here in Oz, they were fitted to Escorts & Cortinas.
In the UK, they were fitted to Escorts, Granadas & I guess quite a few others.
Here's a link to a pic of the 2ltr from my nephew's car from a previous thread
http://www.fordforums.com.au/attachm...chmentid=12456
It's an injected 205 2ltr, but they are all the same externally.
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2006, 07:42 PM   #4
Aussie_Escort
Thanks for the replys guys!!
Were 205 blocks in any cars in Aus or only in the UK?
Thats a nice looking engine tufLTD!!
Old 16-03-2006, 07:56 PM   #5
tufLTD
tufLTD
tufLTD's Avatar
They were only fitted to UK cars, very strong blocks & cranks. There's a place in Brissy that imports them.
The pic of my nephew's engine was from a feature article in Hot 4's. It's a pretty nice Escort.
Old 17-03-2006, 09:21 AM   #6
whooligan
whooligan's Avatar
They are called Pintos as they were originally designed for the US Ford Pinto. This car was short lived because they kept catching on fire because of a common electrical fault. The 205 block was used in the sierras injection cars and became the basis for the cossie engines. Has a thicker wall and more suited to turbo applications than the standard block. Its all a much of a muchness as I've found the older TC cortina engines hold up better than the later Escort/TE Cortina ones. You'll find the rings go on the older ones, whereas the bearings let go on the later ones....You take your pick.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2006, 06:14 PM   #7
frogscort
froggy
the 205 was a four wheel drive block , or the basis of the YB cosworths which were turbo'd
frogscort is offline   Reply With Quote Multi-Quote with this Post
