Old 23-11-2005, 07:36 PM   #1
Damo
Default Compression Lock up
Is it normal for the rear wheels to chirp when changing down at highish revs. Like for example i'm cruising along at 70 in third and quickly change down to second letting the clutch out quick :eclipsee_ , both my rear wheels chirp. It sounds mad lol, and when i'm cornering and do it, the car skips sideways. :P
So is this pretty much normal ? Is it just cause i'm reducing the speed quickly with gears instead of brakes ? Some one explain please. :eclipsee_
Old 23-11-2005, 07:38 PM   #2
dansedgli
dansedgli's Avatar
Yep its normal, the wheels are going faster than the engine speed so they lock up for a split second.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2005, 07:39 PM   #3
needfordspeed
Yeah i'm pretty sure it's normal, don't know if it's good/bad for the engine/gearbox. I used to do it with my celica paddock bomb, but I shifted from 3rd to 1st at high revs It was great fun!
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2005, 07:41 PM   #4
zetec
Zoom Zoom
zetec's Avatar
This is normal when you change down at high revs, although not recommended as a cornering technique!!
2012 Mazda3 MPS
zetec is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2005, 07:42 PM   #5
Obriza
Obriza's Avatar
yeh thats normal, the only thing is that i hear that it can be bad for your transmission, apparently it reduces its life. but for that time its still good its great fun
Obriza is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2005, 07:52 PM   #6
ninja
top loader
ninja's Avatar
in my job i sometimes drive toyota troop caryers i love doing it in the city because the weels lock up for a long time and eco`s off the offices and every one looks around and i dont care about the trans or engine or tyers cos its not mine
ninja is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2005, 08:09 PM   #7
Damo
Haha, I don't do it often nor delliberately well i have a couple of times now, it happened on the sorrento cruise around one of the twisties and i loved it lol. Freaks onlookers out too. : My rear tyres are real hard compound so they chirp like mad, it's loud as. :P
Old 23-11-2005, 08:13 PM   #8
parawolf
beep beep
er, I wouldn't be doing it in an uncontrolled (public) environment, esp with cars around... Compression lock up could cause your car to spin very easily as it is very much an 'out of control' moment.
I've experienced it on a race track once, and that was enough.
Nothing to see here, move along, move along...
parawolf is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2005, 08:17 PM   #9
JUZXR8
Hmmmmm
JUZXR8's Avatar
yeh i can get the 4spd auto to do this, goin up from 1st to second and then again from 3rd down to second....wheel spin it into gear
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2005, 08:53 PM   #10
PULLY6
PULLY6's Avatar
Shift kit works much the same Juz.
Damo, you mad c^nt
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust
PULLY6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2005, 08:56 PM   #11
AdzT3-146
own the road
AdzT3-146's Avatar
hehe, you chirped it a couple of times on the cruise back to mornington from sorrento
T3 TE50 #146
Originally Posted by UNR8D
Id rather date a goat with syphilous then drive a maloo.
AdzT3-146 is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2005, 09:06 PM   #12
bdennis
Hmm. Mental note to self.
If I ever come on a cruise. Stay clear of those doing compression lock ups.
IMHO. NOT a good thing to be doing for mechanical and safety reasons..
bdennis is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2005, 09:12 PM   #13
sphell
sphell's Avatar
LOL Damo your a sick : Always hammering some form of E-series in some way :P
Old 23-11-2005, 09:17 PM   #14
damo03
BBQ gas User
damo03's Avatar
Haha. Yeah compression's are great fun, but they put a fair bit of stress on the driveline, esp if you have wide tyres...
I did the first one, in my xf today after droping it back to second at about 90 after only having the manual in the car for 1 day; read thread: "manual conversion dramas!"
Damo
1974 TC Cortina Sedan (sold); 1974 TC Cortina Wagon (sold); 1987 XF Fairmont Ghia (flooded); 1985 XF Ute 351 T5 (sold); 1995 EF Falcon (sold); 1999 Pajero & 2007 Aurion
damo03 is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2005, 09:21 PM   #15
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2005, 09:28 PM   #16
Damo
lol... and out come the nancies. I just wanted to clear something up. I don't plan on doing compression lockups every time i go for a spin. Just wanted to make sure it's normal for the car to do that.
Thanks for the replies. :P
Old 23-11-2005, 11:20 PM   #17
tick5.0
Want some classic?
tick5.0's Avatar
If you want maximum engine braking you need to 'heel toe'.
As your down changing, brake with the ball of your foot and blip the throttle with your heel to match the engine revs with the road speed. Takes a lot of practise though.
Originally Posted by Walkinshaw
all i hear is wah wah wah a plastic car is quicker than my boat anchor
EF II XR8, Supercharged manual *** FOR SALE ***
XC Falcon, waiting for the Clevo & C4 - Sold
AE101 Corolla, the daily - Sold
SII RX-7, original - Sold
BF II GT
Alfa Romeo 156 JTS, the new daily
Z31 300ZX Turbo
tick5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2005, 10:26 AM   #18
gozza
gozza's Avatar
i do that basically all the time i change down for corners....if you match the revs proply you don't even feel the shift
i saw an rx7 on a drag strip(video) just maxxed out....took his foot off the throttle...changed down a gear...the car went sideways then got airborne and flipped
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2005, 11:06 AM   #19
parawolf
beep beep
Out come the nancies? Sorry but doing dangerous driving on the road can only lead to bad things. If you are doing this on purpose it will only be a period of time before you blow something up, damage your car, or worse someone else's body or car body.
Sorry driving like this on public roads is not to be celebrated. :
Old 24-11-2005, 11:19 AM   #20
Kenaz
Kenaz's Avatar
Are you serious? How do you do that?
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2005, 11:38 AM   #21
PULLY6
PULLY6's Avatar
(dirt road)
Old 24-11-2005, 01:15 PM   #22
montyv8
Turbo Dinosaur FTMFW
montyv8's Avatar
only in e-series.......
1973 XB Fairmont Coupe, turbo EFI SBF
8.23@168MPH
montyv8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2005, 04:25 PM   #23
Damo
FFS, It was the first time it happened and was far from dangerous. Assumption is the mother of all ......... Only reason I started this thread was to get a better idea of why this happens, not to be accused of driving like an idiot and endangering the publics lives or blowing my car up. :
Old 24-11-2005, 04:42 PM   #24
Shonky
my other ride is the bus.
Shonky's Avatar
Oh dear... I can see where this is going...
Anyone else hear the sounds of Padlocks and chains?
1994 ED Fairmont Ghia (Retired to the shed...)
1999 AU Futura
+ Lots of Land Rovers
Originally Posted by Sourbastard
Edelbrock.... not Peter Brock. Theres a world of difference. For a start my heads have much less gum tree in them.
Shonky is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2005, 04:54 PM   #25
Obriza
Obriza's Avatar
yes i see what you mean, seems to be getting that way :
Old 24-11-2005, 05:06 PM   #26
Damo
Thanks for your valuable input. :monkes:
Old 24-11-2005, 05:07 PM   #27
mcflux
mcflux's Avatar
A mate of mine put lumps on both sides of my head once when travelling in his dual cab hilux...
compression lock = I smacked my head into the drivers seat (I was sitting in the back)
sudden acceleration after compression lock = I smacked the back of my head against the glass behind :S
Damo you're sik :P My old man's VZ chirped for the first time ever today, but that's because it takes an age to go between R and D, and while it was somewhere in the middle I got impatient and applied some throttle... 2500rpm + N into D = VZ chirp. It's weak :P I hate it.
Old 24-11-2005, 05:08 PM   #28
Psycho Chicken
Psycho Chicken's Avatar
Originally Posted by PULLY6
(dirt road)
Naw, put it into park.
Old 24-11-2005, 05:29 PM   #29
LUXO_8
windsor user
i always slow the hilux with the gearbox and not the brakes or a combo of both most of the time there is a very slight comp lockup....(sometimes its pretty loud lol...)
ive done it the whole time ive been there (5 years / 350,000 kms) and the thing just wont die.......infact, no matter how hard its thrashed it keeps going and going..
hilux's are great to thrash
Old 24-11-2005, 06:17 PM   #30
damo03
BBQ gas User
damo03's Avatar
I used to do heaps of compression lockups in my old man's nissan patrol in the wet. It was great because you didn't have to goo too fast to lock it up in second as it was quite low geared. For a 4x4 the patrol handled like a car when sliding; no body roll!
