Old 02-11-2005, 09:04 PM   #1
Esky_Owner
Default Escort Speedos
G'day all,
Got a problem with the speedometer. '76 MK 2
When I come to a stop it drops below the 0 ( Zero ) thus throwing it out by 20kms / hour.
Anyone know of a fix for this ? And NO there are no stopping pins on the dial for this model, its all hidden behind.
Thanks
Old 02-11-2005, 10:51 PM   #2
The MaDDeSTMaN
No longer driving a Ford.
The MaDDeSTMaN's Avatar
Never heard of that happening, and I no longer have access to an Escort to have a look for myself to try and find the problem and solution. First thing that came to my mind was that the speedo itself may need to be rotated so it sits on 0km/h when you're not moving, however not sure how to do that or if it's even possible, sorry.
Originally Posted by russellw
For those who get their jollies attacking other people let me remind you that we will not tolerate this here. If you want to do that then I am sure your presence would be welcomed elsewhere.
The MaDDeSTMaN is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2005, 02:18 AM   #3
Esky_Owner
Rotating the speedo wont work as the trigger for the trip meter is in the way
Anyone else got any ideas ?
I'm in Queensland and I do believe there is a speedo shop somewhere near Rocklea / Coopers Plains. Have no-idea where it is.
Dearly need help
Thanks
Old 12-11-2005, 10:06 AM   #4
rag top
rag top's Avatar
Do you have access to a spare speedo to try??
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2005, 04:16 PM   #5
Esky_Owner
No unfortunately :(
Old 12-11-2005, 06:13 PM   #6
12
Silhouette AU1 TS50.
12's Avatar
I think your needle might have been moved from it's correct position. Maybe try removing the cluster, then the speedo itself and align the needle.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
12 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2005, 10:12 PM   #7
Esky_Owner
Thanks, will see if it can be done
Old 13-11-2005, 09:32 AM   #8
rag top
rag top's Avatar
What dash do you have at the moment? I can check to see if my mate has a spare.
Current Rides:
Old 13-11-2005, 05:39 PM   #9
blitzmile
so is the speedo totaly out of wack, like when your driving 60 its reading 40? id pull everything apart and check myself
blitzmile is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2005, 09:12 PM   #10
Esky_Owner
What I might do is put an internal stopper so the clock stops at 0 ( Zero ) not under ... It may work
Let you know
Old 19-11-2005, 05:26 AM   #11
Scort
my speed and rev gauge are crazy
mind of their own
Scort is offline   Reply With Quote Multi-Quote with this Post
