01-02-2005, 11:15 PM | #1 | ||
Hi people - I am in a bind.
I need a series 1, series 2 and series 3 V8 owners to post up the numbers on the Mass airflow meters so we can get support from Pro-M for replacement/upgraded meters. Can you please post up your MAF numbers and where it comes from (ie. Series 1 AU - 19lb/hr injectors) Shane Your Australian Pro-M distributor
...Mr Landau and his low flying aircraft provided much entertainment for my daughter who stated and I quote: "That mans car is too loud! Why is his car so loud? Is there something wrong with it?" "No" I replied. "But there might be something wrong with the driver"... Growing old is inevitable :eclipsee_ Growing up is optional :eclipsee_ |
02-02-2005, 12:29 AM | #2 | ||
Hey shane, heres one of mine, off an au1 non xr.
>PBT-GF30< F57F-12B579-CA 8E27 -2 ill get the one off my car for ya tommorro mate, tis an au2 xr8 200kw. cheers, phil. |
02-02-2005, 12:46 AM | #3 | ||
Thank you.
02-02-2005, 08:14 PM | #4 | ||
AU1 TE50 200kw - Not 100% sure on injectors, but I think 24lb ?
F57F-12B579-CA 8F04 - 2 |
02-02-2005, 09:41 PM | #5 | |||
You already have an AU1 but I thought I'd put mine up anyway as the thrid number is different.
AU1 F/Ghia V8 >PBT-GF30< F57F-12B579-CA SJ30 - 2 4853288 What are these numbers anyways?
03-02-2005, 12:16 AM | #6 | ||
The important number is the F57F-12B579-CA. The first 4 alphanumeric code desigantes what the meter is designed for. ( F5 = 1995 ) - the numbers after go into the specific model.
Does anyone have a series 1 XR8 MAF meter for me - I am sure the numbers will be the same. These were all 19lb injectors on the series 1 weren't they? Shane
03-02-2005, 01:09 AM | #7 | ||
yes mate, all au1's were 19lb, au1 t series were 24lbs(they had the 200 kw motors) au2 xr8 had 24lbs(200kw) 24lbs for the 220kw, and 24lb for the 250kw strokers.
I think au 2 no xr had 19, while later au2, and au3 non xr had 24lb. sorry mate, was ****ing down rain all day, didnt get to look under the bonnet, mine is an 200kw au2 with 24lb injectors. |
03-02-2005, 02:04 AM | #8 | ||
It is very interesting that the TE series used the same MAF as the base V8 - hinting that the AU computer is more like the 94/95 mustang computer in that the computer in this series controls the injector curve and not the MAF like the Eb-ED and pre 93 mustangs.
Shane
03-02-2005, 01:51 PM | #9 | ||
A little bit off topic, but how can you tell what lb/hr injectors you have? I have 99 model XR8 and it's got blue injectors - the same as my AU2 V8 forte, and Muzz's AU2 200kw XR8. I would have thought that the same colour would mean the same rating. Is that incorrect? How else do you tell - like is it printed on the injectors anywhere?
MAF (AU1 XR8 auto): F57F-12B579-CA
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, HSD/ShockWorks, black GT335 19” staggered replicas with 245 & 275/35/19 Michelin Pilot sport 5s Daily: BF2 Fairmont Ghia I6 ZF, machine face GT335 19” staggered Replicas with 245s and 275s, Bilsteins & Kings FPV 335 build stats: <click here> Ford Performance Club ACT Last edited by JC; 03-02-2005 at 03:07 PM. |
03-02-2005, 04:33 PM | #10 | ||
The series 2 and 3 AU's use Bosch EV6 24lb/hr injectors which are blue. The series 1 AU's use Bosch EV1 19lb/hr injectors which are orange tops and grey bodies. The GT's, Sprint's and FBT's use Bosch EV1 24lb/hr injectors.
Shane
03-02-2005, 05:11 PM | #11 | |||
I have a 9/98 series 1 with orange (more a brown colour actually) EV6 style injectors - these look exactly the same as the blue ones except for the colour. I have contacted Bosch about these (giving them the part numbers) and was told they have the same flow rate as the blue injectors (also gave the part numbers for those)... this is what they had to say "The injector pictured is part number 0 280 155 903, the brown/orange injector referred to is part number 0 280 155 917. Both of these injectors have a flow rate of 150.2 g/min which loosely equates to ~ 24 lbs/hour." I must admit I've never seen an AU with EV1 style injectors.
03-02-2005, 05:21 PM | #12 | ||
Oops... forgot - my MAF number is F57F-12B579-CA, so the same as everyone else's so far (AU series 1 Ghia with std V8).
03-02-2005, 05:56 PM | #13 | ||
Back on the road
I've got a series 1 XR8 (build 11/99), so I'll check the MAF for you tonight. My injectors are the blue EV6 type as well...
03-02-2005, 09:46 PM | #14 | |||
The MAF function can still be used to upgrade the injector sizing - I just need to determine 1. What the meter we use on the AU's is used for on the American counterpart (already chasing that one) 2. What model computers modify the injector pulse width for the larger injectors for ordering purposes. Anyone in Adelaide want to be a guinea pig for me and test some MAF's? Shane
03-02-2005, 11:11 PM | #15 | |||
I would suggest that the AU1 XR8s came with the blue injectors, and the non-XR V8s didn't.
03-02-2005, 11:59 PM | #16 | ||
Back on the road
MAF;
F57F-12B579-CA 9A05-2 6092324 Injectors; XS2E-B5A 0 280 155 908 edit: may be 0 280 155 903?? For AU1 XR8 build date 11/99. As far as EV1 vs EV6 injectors on AU's, it is probably more likely build date related than a hi-perf vs lo-perf thing. I think the EV6 injectors were introduced (in American Fords) sometime during 1999, so it would make sense that the same thing happened here. Last edited by xr8ute; 04-02-2005 at 12:05 AM. |
04-02-2005, 12:05 AM | #17 | ||
I have only genuinely looked at the 1st of the AU's when they first came out. The one's I saw still had the orange EV1 injectors on it.
I do not profess to know all about the AU's - this is why I am here asking for your help. In the end - you will be the one to benefit if I can get you Pro-M 70mm meters for your car for $380 To put that into perspective - I was looking at $330 change over trade price for one when mine suffered 1 too many LPG lean backfires or over $1400 trade from Fords. Shane
04-02-2005, 12:30 AM | #18 | |||
Does anyone have the EV1 type in their AU and if so what is the build date? |
04-02-2005, 12:52 AM | #19 | ||
I thought the EV6's were fitted to all modulars which makes them 1996. Corral is not working for me ATM so it is hard to confirm.
Shane
04-02-2005, 07:16 PM | #20 | ||
ok, heres the maf numbers off my au2 xr8, 200 kw(2001model)
>PBT 0F30< F57F - 12B579 - CA 0K02 - 2 2727078 mine has the blue 24lb injectors. |
06-02-2005, 05:35 PM | #21 | ||
This is off my Dads 01/00 series 1 XR8 auto
F57F-12B579-CA 9L04-2 9108823 Has blue injectors engine code Z We are assuming it's 185kw but the dealer said it's a 200kw so your guess is as good as ours. Will get the numbers off my SII XR8 Ute as soon as it's here again. Neil |
06-02-2005, 06:12 PM | #22 | ||
Thanks guys. Any series 3 owners out there?
Shane
10-02-2005, 02:37 AM | #23 | ||
I took what information I had to Jim from Pro-M and it looks like I have to send an AU meter and AU airbox over so we can get the correct calibrations sorted for the AU Falcons. 2 weeks and we should have it sorted.
Shane
22-02-2005, 12:35 PM | #24 | ||
Jim has received the meter and has entered the calibration into the database. Has anyone got any dyno results showing air/fuel ratio's on standard motors so we can see if it needs fuel added or pulled at any of the manipulation points.
Your help is appreciated - and it is you who will benifit the most from this. Shane
22-02-2005, 12:58 PM | #25 | |||
How standard does it have to be? Only things changed from stock on this run is the BMC filter, XR8 extractors/cats and 3" exhaust. By the look of the A/F ratio though I might have a buggered oxy sensor?
http://fordforums.com.au/attachment....achmentid=1394
22-02-2005, 11:22 PM | #26 | ||
I guess the more standard the better - if we can get some knowledge base on what the standard meter does on a standard car - we can manipulate the injector pulse width at various points on the injector curve to get the air/fuel ratios as flat as posible across the board.
Shane
