KITTY Crew Member
Hi, guys.. please dont think this is a stupid question, but how do you check your oil.
I was told by 2 Ford service people to check my dipstick within 10 seconds of shutting down engine ![]() This was after I complained that they overfilled my oil ?? If true why would we all of a sudden be doing things differently. Surely it would be better to wait for the oil to get back to the sump and settle to give you a true indication of the level. I mean this is against the grain of all teachings I know of. Why not raise the mark on the dipstick and check it the old fashioned way. Or have I been doing it wrong :monkes: John
FOR SALE BAII Super Pursuit 0083 ![]() Awsome power by XTREME FORD TUNING 500rwkw New ALLOY Block Awesome exhaust by THE EXHAUST CENTRE MIDLAND Awesome Kenne Bell Supercharger setup by AGRO! and Bluepower Racing Developments Now with full DOT approval and Permitted for road use
Turbo Falcon Fiend
I wait for the oil to get back to the sump. That will give you (on DIY service) about 5 - 5.5 litres oil capacity.
The one and only
I use the dips stick..... (had to be said)
I always check when cold. The auto trans has to be checked within 10 seconds of shutdown. Again Ford service is wrong!!
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
You always check oil, when its cold. This is when the oil is at its correct level. Hot oil has expanded and gives a false reading. My Ford has a sealed auto box, cann't check.
#5 | |||
Foo Fighter
KITTY Crew Member
this is my engine oil i am in about.
Check when cold, as others have said. I'm not sure why the Ford mechanics would advise otherwise, but I've always been taught to check oil level cold.
M14A-Mclaren - Some auto boxes are sealed and don't require the oil to be changed at all. I've seen BMWs like this, didn't realise Ford was doing it too. |
KITTY Crew Member
I am with you all on the way to check. How it came about was
I took the ute in for the 3000 km check, knowing i needed a pint of oil. They did not even top up the oil. So I voiced my concerns re there "service". So they topped it up for me. Next day I thought I would check it in morning and found it about an inch above full. I thought it was too full and wanted them to drain it out. And this is how the story begins, Not happy !!
#9 | |||
The one and only
But this is O/T ![]()
#10 | |||
not here much anymore
RAM 1500
#11 | |||
_Oo===oO_
Back on topic it's definitely tripe. Probably not so much that they don't know any better. Too lazy to drain the excess oil and admit their stuff up.
#12 | |||
T1 TE50 Galaxy Blue #010.
Location: In between German Engineering and Tickford Perfection.
Engine oil i check with car cold and on level surface, i'd say as per usual it is Ford service trying to talk about something they know nothing about, happens quite often. |
#13 | |||
This is an exact copy from the Territory's Owners Manual, it is relevant to all engines;
Slightly over full wen hot shouldn't be a problem and is caused, as others have mentioned, by thermal expansion. Having the engine too much over filled can cause premature engine wear through the oil being aerated. It can also cause higher fuel consumption and power loss, these are extreme cases caused by an excessively overfilled engine sump. As for the auto trans, check here; Servicing a Territory/Falcon Automatic Transmission The new 6 speed ZF will be different again (if it is anything like the ZF in the BMW), still no dipstick, but it will confuse a lot of people. My lips are sealed ![]()
The true danger only occurs when you take a potentially dangerous piece of machinery and place it in the hands of the most unpredictable species on the planet. Human behaviour, as history has catalogued, cannot account for what any persons actions may be, especially concerning their love of the motor vehicle. http://www.fireservicecollege.ac.uk ![]() |
#14 | ||
Should check when cold and drained back to sump as said. Also, you should be sure to drain some off if they've over-filled it 'cause over-filled can lead to aeration of the oil and thus improper lubrication and lifter operation etc.
#15 | ||
LOL, beat me to it johnydep - I was sitting writing my post for ten minutes 'cause of watching the tele at the same time
#16 | ||
KITTY Crew Member
Man am I going to let Ford have it. I said to them exactly what you guys are saying. I even made sure to have it on level ground. I will be looking up the required litres and making them drain and fill. Then with the right volume in sump they can check the dipstick. Lazy mongrels $60k for a ute and this is the type of service you get.
If I did not love Fords so much I might be driving a mazda (never a Holden ![]()
#17 | ||
burn out king
i check mine about every 3 months. and hey the old eb dont use none
#18 | |||
Cruisin' When-ever I Can!
I check my oil after running the engine but after everything in the engine bay has cooled to a point where you can touch it. If it is a little bit overfilled it wont matter much...
2006 BF XR8 - Lightning Strike - Herrod quad system with Herrod extractors, Coil overs, Whiteline swaybars, Powerbond 25% Underdrive. More mods to come! Ex 97 EL Futura, 04 XR6 and 07 XR8 Owner. |
#19 | ||
KITTY Crew Member
Well I called FPV direct, because my local service centre is still telling me stories. Very helpfull at FPV. Tony told me this.
1) Warm up car/oil 2) put car on firm level ground 3) Shut down engine and wait at least 5 minutes 4) Check the oil, and make sure the numbers are facing the block to get the most accurate reading Pretty clever at FPV eh ![]() Now to visit Titan (oops, wasn,t supposed to say that) to replace my oil. Unless they can prove to me I have not had any aeration and wear happening for the last 1500km. (Looks like they will be replacing my oil and filters)
#20 | |||
trying to get a leg over
![]() Join Date: Dec 2004
Cameron ------------------------------------------------------ |
#21 | |||
KITTY Crew Member
I was told by good scources that my Ford service centre is the best we have to offer. Does anyone know of a service place that respects our Fords as we do
#22 | ||
IWCMOGTVM Club Supporter
I was always taught that you check your oil when the engine is cold. But after reading this thread I decided to look at the manual and it said that it should be checked when the engine is at operating temp (also to wait five minutes for the oil to drain).
So this has thrown me. But I guess I can trust the engineers. |
#23 | ||
Performance moderator
![]() Join Date: Feb 2005
Use the dip stick first thing before starting it on level ground...But checking after re fueling is o/k...
If the oil is low ??? Go to parts dept and get another dip stick....
#24 | ||
I let it sit overnight on a flat and check it first thing in the morning ,thats how ive always done it.
by the way wheres the point of checking the oil while its hot ?
QUOTE I hope your opinion of the rear end of the VE improves because you are going to be seeing a lot of it.QUOTE QUOTE What makes you think I'm going to park behind a VE? I don't even attend the Sydney Gay Mardi Gras! QUOTE |
#25 | ||
GT
mmmmmm . now with the ba gt i have had the dealer top it up at 3000km when i drove it home it was about 10mm above full dipstick . when i changed the oil myself i put about 5.5 litres of oil; into the engine which filled it to ful . i found this strange , because the manual says that the BOSS
#26 | ||
GT
mmmmmm . now with the ba gt i have had the dealer top it up at 3000km when i drove it home it was about 10mm above full dipstick . when i changed the oil myself i put about 5.5 litres of oil; into the engine which filled it to ful . i found this strange , because the manual says that the BOSS ENGINE SHOULD TAKE 6.2 LITRES OF OIL TO FILL . WHICH I THINK WOULD GIVE IT ABOUT 20MM OVER THE DIPSTICK FULL MARK .GO FIGURE .
#27 | ||
nitro addict
i check my oil first when its cold then warm the car up let it sit for 10mins then check it once more just to be sure beta to be safe then sorry both times the reading is pritty much the same hot an cold
#28 | |||
Life is a Ride!
I used to work at your service centre, as sales person. To put it this way, I don't work there anymore and I bought mine from Challengers in Rockingham. Must say that i am very impressed so far. Go see the Service manager direct Mr Carkeen I believe. Tell him Barry with the low Acid Rush XR6T send you. Or else you could ask for Scott Percell first and explain to him. He is a used car sales person and old collegue of mine. Baz |
#29 | |||
Official AFF conservative
Could have swork ATF check (for those of us lucky enough to have dippy on trans) was done with engine running and transmission in P.. after working box through the gears.
A cup half empty... but full of euphoria. |
#30 | ||
I have a dipstick for my AU's auto... And that is how I check the level in the trans. No crawling under the car and stuffing around to check it.
Current Rides: 2000 AU 5L XLS ute; 1970 Mustang project |
