29-08-2005, 10:58 AM | #1 | ||
FRIKA
Im looking at getting my AU2 XR8 lowered. King Springs Superlows. 25mm front and 35mm rear.
Has anyone had the same done? If so did you encounter any problems. The suspension joint told me that maybe ill need to fit in a front camber but that should be my oly problem?????????????????? cheers
New 2008 LV Focus XR5 in Performance Blue
29-08-2005, 11:06 AM | #2 | ||
they call me Tibbo
I'd recommend rolling the guards.. mine scrapes on full lock but other than that no issues... I didnt need a camber kit either...
29-08-2005, 02:47 PM | #3 | ||
FRIKA
cheers.
ive been told that it only scrapes the guards when you have 18" rims. Mine are only 17". Are yours 18" and how low is you car?????????????? from the middle of the rim to the guard?
31-08-2005, 01:00 PM | #4 | ||
i fitted king spring lows to my AU1 and didn't fit a camber castor kit and mine seems fine after 12 months
the only trouble i encountered was going from stock height you need decent spring compressors cause the spring a christmas tree shaped and it is a bastard getting the cheap spring compressors on there i got 18's and haven't rolled the guards no trouble scraping on front or back even on full lock |
31-08-2005, 04:38 PM | #5 | ||
FRIKA
Cheers MattsAU1,
How low is your card from middle of rim to guard?
31-08-2005, 07:56 PM | #6 | ||
tis 345mm give or take a few
370mm back again give or take a few i did my best to keep it within RACV guidelines but am thinkin bout dumping it completely can you or anyone else recomend an insurer that allows you to do this and still be covered cheers |
31-08-2005, 08:19 PM | #7 | |||
Me fail English? That's unpossible.
31-08-2005, 08:55 PM | #8 | ||
FRIKA
Yeah im looking at 340mm front and 345-350 rear.
not sure about the insurance. I spoek to a guy that works for a suspension place and he has been in the industry 15+ years and has never heard of anyone being denied a claim because the car was to low. My EA was illegal and i nearly wrote it off. Insurance covered the claim. could be different now. that was with GIO i think.
04-09-2005, 10:46 AM | #9 | ||||
If you ring them and ask they will tell you a 30mm drop is maximum. No worries, you already know that. Now, for fun, ask them to tell you what the baseline hight is, that is, the original stock height... prepare for 20 minutes of wasted time (make a coffee and have some snacks ready before you call). End result... they have NO IDEA. They say you can drop it 30mm but wont say from what original height. So the answer is? Well, based on documentation I got from an Official Ford AU service manual (used by the dealer service area)the official factory figures are: Front 367mm / Rear 377mm (for IRS fitted models) Therefor the insurable ride height for your car is: Front 337mm / Rear 347mm So you can actually go lower than you first thought. Quote:
Hope that helps.
04-09-2005, 01:23 PM | #10 | ||
My service book also mentions the stock heights of 367/377. I've measured the XR8 (stock height) and it's 354 front, 370 rear from centre of wheel to wheel arch. The wagon is 340 front, 347 rear (not stock - superlows in front, reset leaves in back)
04-09-2005, 01:33 PM | #11 | |||
04-09-2005, 01:38 PM | #12 | ||
So you mean I should have asked you to get out of the car first?
04-09-2005, 01:41 PM | #13 | ||
You have to ask nicely
04-09-2005, 09:43 PM | #14 | ||
Matts AU, did u change ur shocks aswell?? How does the AU feel now on the road, any differences in the handling department?
05-09-2005, 01:34 PM | #15 | |||
handling is much better there is a rondabout near my place that is sorta a good test (provided you dont get caught) at stock height i was able to go through it at bout80-85kms/hr and the *** was all over the place with stock rims too i might add with the 18*8's and the king spring lows i can hit it and accelerate through it at about 120kms/hr so you be the judge i reckon its pretty good and it stuck to the ground like to a blanket will prob replace the shokers if i do end up going any lower though |
05-09-2005, 05:46 PM | #16 | ||
Irregular Member
I fitted my Au2 forte with King superlows and koni adjustables.No probs with scraping on 17 x 8s.I have had probs with the camber kit fitted,im going to replace it with a Whiteline one (apparently doesnt use shims).
Im with Just Cars Insurance and i told them the car was lowered and they didnt want any specs of how low at all. |
05-09-2005, 06:33 PM | #17 | ||
FRIKA
sounds good.
ill see how i go first with just the king superlows and cross my fingers that nothing else is required. i spoke to guy on the weekend with an au2 xr8 and he said pretty much ok only when going up kerbs on driveways and when steering fully locked that it scrapes the guards.
05-09-2005, 08:01 PM | #18 | ||
Irregular Member
You shouldnt have any dramas with scraping on full lock.Are you going to fit superlow springs with stock shocks? I didnt think you could.
05-09-2005, 08:03 PM | #19 | |||
05-09-2005, 08:21 PM | #20 | ||
If you look at the monroe site, the shock spec for low, superlow or SSL is all the same. Even konis, the spec is all the same. The difference in putting in a lower spring is in the rebound rate - ie it affects the rate of the shocks, as a ;ower spring generally reacts quicker than a stock spring, and the shock may not fully handle this increase. So if you go standard shocks like monroe, you will always end up with a harsher ride. If you go with adjustable konis, at least you can adjust the comfort setting so it's not so harsh.
05-09-2005, 09:32 PM | #21 | ||
justa6
Just make sure you go low enough. I went lows and now superlows, now thinking of getting customs. It has 19s under it and has never scraped. It was chopping out inside fronts so had to put a camber kit in it
05-09-2005, 11:13 PM | #22 | ||
I've asked this a few times and never got an answer! I had a look in the monroe catalogue and the listed shcokers for a lowered AU are the same as the schokers on a standard XR6. The front ones are the same regardless of it being a standard falcon, lowered falcon or tickford falcon. so my question is, if i have a Xr6 with the short shocks on it anyways why would i need to change them if they are going to be the same thing!!
05-09-2005, 11:17 PM | #23 | ||||
05-09-2005, 11:21 PM | #24 | ||
so Casper what brand schokies do u think is suitable for an AU XR??
MATTSAU1, any before and after pics of your car? |
05-09-2005, 11:35 PM | #25 | ||
Depends on what you can afford.
I've actually heard that the Monroe GT's ware a good match (but dont have a huge lifespan - 50,000kms is really it but you get what you pay for) but Koni's have to still be No1.
05-09-2005, 11:45 PM | #26 | ||
XR6007 - find a shock manufacturer that lists a shorter shock for low/superlows, and that is the shock you should get. I don't think you'll find one though. I know there was some for the E series, but haven't seen any for A series at all. Adjustable shocks (eg Konis) would therefore be your best bet as you can adjust the setting to suit the springs. The adjustable does not refer to height, but comfort settings, from sport (hard) to comfy (soft). Note that the term "soft" is used in a relative sense when talking lowered springs - it's all hard, just not as hard on a soft setting.
06-09-2005, 10:06 AM | #27 | ||
Thanks Casper and JC, its cleared a bit of my confusion.
Well monroe have the GT and also the sensatrac available!! Should the front ones be changed to, considering its going to be a standard replacement Oh and how much are koni's? Last edited by xr8 007; 06-09-2005 at 11:22 AM. |
06-09-2005, 12:25 PM | #28 | ||
FRIKA
I rang several suspension places and asked if I was to put superlows on would i need to change my suspension. Not one of them said i did.
One place said that Koni i think have just bought out a short front shock to enhance the ride. Who knows wether any of them are telling the truth??????????????????
06-09-2005, 12:44 PM | #29 | ||
Irregular Member
Konis are awesome shocks!!!! Im thinking of upgrading my adjustables(the ones you have to take out to adjust) to the ones you can adjust with the dial thingy ontop.When i ordered mine they didnt have any of the adjustable ones with the dial ontop in the country.
08-09-2005, 11:31 AM | #30 | ||
FRIKA
thanks for everyones help
Today is dump day. Cant wait to see the result after work.
