29-07-2005, 02:37 PM | #1 | ||
G'day guys Thease are the things i have already done in it.
POD air filter XH Snorckle Sports Exhaust (SOON) What other Performance Mods Can i do on it??? |
29-07-2005, 02:56 PM | #2 | ||
Buy sunny's turbo kit
29-07-2005, 02:59 PM | #3 | ||
How Much And What aels
29-07-2005, 04:35 PM | #4 | ||
yoohoo anyone there
29-07-2005, 04:54 PM | #5 | |||
own the road
do u wanna keep it N/A or go for turbo?
T3 TE50 #146 Quote:
29-07-2005, 04:59 PM | #6 | ||
Probly N/A
29-07-2005, 05:02 PM | #7 | |||
own the road
Get Exhaust/Extractors, LSD, Bigger Cam. that should get ya started and occupied for a while.
T3 TE50 #146 Quote:
29-07-2005, 05:05 PM | #8 | ||
Whats a LSD and Cam???
29-07-2005, 05:08 PM | #9 | ||
They go in your intake. They improve powah!
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
29-07-2005, 05:17 PM | #10 | ||
Whats involved in doing that
29-07-2005, 05:27 PM | #11 | |||
Shoot.
20V Turbo |
29-07-2005, 05:39 PM | #12 | ||
Snorckle . tehehe made me laugh
Extractors and exhaust first, then look at change the cam. There are heaps of threads on here regarding Cams that guys have chosen. Just do a search
Heritage Green EL Ghia Black AUII XR8 Ute |
29-07-2005, 05:46 PM | #13 | |||
own the road
Also dude, check out JMM (site sponsor) link at the top of the page. get a DEV3HL kit if u can wait to save your pennies.
I'm pretty sure they can send it over and an Exhaust joint in WA would fit it for ya.
T3 TE50 #146 Quote:
29-07-2005, 06:34 PM | #14 | ||
i got a hotted up eb2 making 140RwKw, now its commiting suicide slowly but surely . But its got headwork, cam, extractors, new gearbox :jab:
29-07-2005, 07:42 PM | #15 | ||
How much money do you want spend?
29-07-2005, 09:08 PM | #16 | ||
A good way to hot it up, would be to douse it in petrol and throw a lit match on it. That would be damn hot!!!!
29-07-2005, 09:15 PM | #17 | ||
windsor user
it would also give you a great flame job...
couldnt resist |
30-07-2005, 09:26 PM | #18 | ||
LSD = limited slip diff. Your normal diff will be an open-wheeler (spins one wheel rather than both, unless you're going absolutely nutbar!). LSDs spin both wheels and are quite fun to have
Cam = a shaft that sits on top of the head (I think! Does OHC = the cam sits over the valves, removing the need for pushrods & rockers?). This shaft has lobes on it which determine when the intake and exhaust valves open & close. A better cam has different shaped lobes so that the valuves open and close at different times, different speeds, different lifts, and different durations/overlaps compared to a standard cam. EG: standard cam might open the valve late and close early so only a little fuel/air mix enters the cylinder, and its lift might be small so that it doesn't let a heap rush in. It also might not overlap with the exhaust valve being open, where unburnt fuel/air can start to make its way into the extractors. This setup will give say average power and good efficiency for everyday driving. On the other hand, you might want it to perform better where it makes power (higher in the rev range), so you might get a cam which allows more fuel/air in due to lift and duration, and has the exhaust valve's lift/duration set to optimum for this too. Since there are so many variables to play with, there are heaps of different cams out there. Try www.howstuffworks.com and search for "camshaft". I haven't done this myself, and the above info was off the top of my head. If anyone can correct me on some mistakes I may have made, or explain some things better, please do so ;) Oh, another idea for hotting up your EB: NOS. Get one of the big bottles. -Dave- |
30-07-2005, 09:32 PM | #19 | ||
To be honest, there are two paths which you should take before undertaking mods on your EB)
Path 1: Do a LOT of research. Read heaps of online info/articles (google & howstuffworks.com are your friends) and borrow books from the library which go into detail for what components do in cars (such as the LSD and cam which I went into in the previous post). Path 2: Look into an "all-in-one" kit such as the JMM ones as mentioned. Saves you the headaches of researching for your own custom setup. I suspect you may be better suited to something like this, where JMM or other companies offer customers such kits (eg "Stage 1 upgrade", "Stage 2 upgrade", etc) which they fit themselves. Save $$$ for either path! -Dave- |
31-07-2005, 12:10 PM | #20 | ||
but dont forget the basics, good injectors, adequate fule supply, good spark plugs and quality oil
car that goes (just) <----- gonna be MENACE so :thebirds: |
31-07-2005, 12:35 PM | #21 | ||
Pods rule
From what i can see of the pictures, a great way to start would be a 5 speed conversion, that will get you going nicey. Also, throw some super lows through it, they'll make it look a treat and corner sh*tload better
31-07-2005, 01:58 PM | #22 | ||
31-07-2005, 02:07 PM | #23 | ||
windsor user
great gains to be had with that thingyjig!
31-07-2005, 05:42 PM | #24 | ||
dice hanging from your rearview mirror works too
01-08-2005, 05:59 PM | #25 | ||
But i dont wont a turbo
01-08-2005, 07:09 PM | #26 | ||
Tough luck, you're getting one anyway :
01-08-2005, 07:14 PM | #27 | ||
GMHKLA number plates
Ey pplz rnt pod filters illegal ne more (go easy im still a learner)
but thats mi beast <<<
Currently owned: 1997 Hyundai Excel (the daily) 2009 FG FPV F6 Silhouette Auto Previously owned: 1994 EF fairmont Ghia 4.0Ltr, AUTO 14.620@93.3mph 2000 Honda S2000 14.73@92mph (stock + no traction) |
01-08-2005, 08:48 PM | #28 | ||
I'll drop a hint while you're learning mate ;) SMS text sucks. Keep it up and you'll "somehow" end up with a Barbie avatar! :
Nice EF by the way! |
01-08-2005, 09:32 PM | #29 | |||
windsor user
02-08-2005, 12:18 PM | #30 | |||
In anwer to your question, pod filters are not illegal if they are placed in an airbox.
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
