18-01-2005, 01:24 PM | #1 | ||
Smile
Just wanted to make this post for those who want the best bang for buck on a daily driven car that wont see the 1/4 mile. Well I must say that the exhaust is the best starting point. In my experience the change to a cat back and Jim Mock race series extractors are money well spent. The standard AU ford comes alive with this addition.The difference for me was amazing!!!
0-100 times will be dramatically improved.To compare ...I have raced 20 odd ss commodores on the street and none of them beat me from 0-100 .All of these were done in an area of 100 kmph speed limit so as to stay within the law and be safer. The next thing that I can recommend is a shift kit for the auto transmission.This alone makes the gear changes quicker . The next thing I would recommend is a chip.I believe that with a chip the power from 0-100 and a little more terminal power will make for very potent AU FORD. My cam swap has so far taken away these so many great qualities that I had.but in defence of it I dont think it is dialled in perfectly yet. Last edited by Stav; 18-01-2005 at 01:29 PM. |
18-01-2005, 02:31 PM | #2 | ||
T3/Sprint8
lol useless, do you stop on the M2 or 3 to get 0 to 100k comparos against SS's ?
You're right with exhaust,chip I had good gains from these 2 alone. Include better air intake flow and the shift kit must be better but I am yet to do this.
18-01-2005, 02:35 PM | #3 | ||
How old are these SS's? Your car must be something special to beat Gen 3's to 100km/hr. I can barely do that.
If your only interested in 0-100 times then short diff gears would help a lot as well.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. Last edited by dansedgli; 18-01-2005 at 02:38 PM. |
18-01-2005, 02:45 PM | #4 | ||
Can you explain the shift kit, bit more for me... I never heard of it...
Have you got an FPV or XR6/8 and live in the ACT or surrounding area? Come and check out the FPV & XR Owners Club of ACT AUI VCT: To date - Big brake upgrade, Koni and Kings all round, 2.5 cat back ready for replacing, 19" again ready for replacing. Planned - Too much now I got the baby back. |
18-01-2005, 05:09 PM | #5 | ||
Cubey - the shift kits is a little electronic box the goes between the ECU and the auto transmission (basically it plugs into the ECU, if you can call soldering plugging something in).
There are 3 versions: 1. Non switchable (firm shift) - once connected, the shift kit is always on. 2. Switchable (firm shift) - you can choose to have it on or off 3. 2 way Switchable (firm or hard shift) - you can choose to have it on firm shift, on hard shift, or off. Basically, the electronic box contains a resistor or two and, when turned on - assuming you get the switchable version - effectively tricks the ECU into thinking that the transmission is not getting enough line pressure for the gear change. It forces a harder (and therefore shorter) shift time. With a firm shift, the rear wheels chirp a little when changing gears, with hard shift, you get quite a bit of wheel chirp (almost wheelspin). The gears also slam in a lot harder and louder, though apparently this does not harm the gearbox as the friction surfaces are actually meeting for less time. Not sure about the diff though. lol With the shift kit on in my car, it makes around 0.1 difference to 0-100 times. I reckon if you could get it to shift harder without getting the wheels to chirp, it would make more difference as the chirp must be costing time. Best $100 I ever spent (I got the 2 way switchable kit)! And I don't use it in the wet - it's too dangerous!
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, HSD/ShockWorks, black GT335 19” staggered replicas with 245 & 275/35/19 Michelin Pilot sport 5s Daily: BF2 Fairmont Ghia I6 ZF, machine face GT335 19” staggered Replicas with 245s and 275s, Bilsteins & Kings FPV 335 build stats: <click here> Ford Performance Club ACT Last edited by JC; 18-01-2005 at 05:12 PM. |
18-01-2005, 06:42 PM | #6 | ||||
Smile
Not trying to glorify the six,but it packed alot more throttle response than I have now with a cam.So why bother? But you can also look at it another way if I can get a chip now with my 141 rwkws the down low power should be restored provided that the tuner realises that 20 more rwkws does count alot more at 60 kmph than at 180 kmph and he fattens up the power as much as possible. Got a bit off track there but in the end I started this to let people know that good gains are there for the 16 in a real street sense. |
18-01-2005, 09:59 PM | #7 | ||
Boss for Go, L98 for Show
My car is a manual, and the best V8 i've challenged is a 200kw XR8 auto. If it was a manual i would be history, let alone a GenIII.
By now VTII and VX GenIII's would have some bolt on mods that would make em go like a bat outta hell. Oh my car makes 142kw at the wheels with a custom intake and cat back exhaust.
Quote: Jeremy Clarkson "The fact of the matter is this, from just about any angle this is an impossibly pretty car" Last edited by XR_Strider_GuY; 18-01-2005 at 10:02 PM. |
18-01-2005, 10:06 PM | #8 | ||
Smile
Believe me now with the cam and the less down low I am being beaten by them. But with the stock cam and above set up I was never overtaken by a gen 3 from 0-100 even if I only had 120 odd rwkws stock
The fact that you have 142 and I now have 141.6 rwkws is irrelevant.The relevant power for 0-100 battles lie in the power in those areas. Think about it...why do turbo cars out accelerate non turbo? Because they produce bigger numbers down low .So even in normally aspirated form this for me is the golden trick. At a 110 kmph a turbo xr6 produces around around 130 rwkws at 90 it typically produces 110 rwkws.If you and I maximised our power compared to that and in theory bettered our power than an xr6t we would blow the doors off an xr6 turbo from 0-100 Last edited by Stav; 18-01-2005 at 10:14 PM. |
18-01-2005, 10:24 PM | #9 | ||
Smile
I am currently fiddling with the vernier and computer to get that awesome feeling again.
18-01-2005, 10:35 PM | #10 | |||
I would say the factory Xr6 cam is tuned for mid-top range power hence my 0-100km/h times are not so impressive compared to rollon acceleration and 1/4 mile relatively speaking.
Quote: Jeremy Clarkson "The fact of the matter is this, from just about any angle this is an impossibly pretty car" |
18-01-2005, 10:38 PM | #11 | ||
The cam is the key in the end. To make big HP there is a trade off....and thats usually the low rpm power. It can be done just right too (Re: Sox and his ute or the JMM EB) but often a trade off has to be made..
Unless you have a VCT :nutsycuck (you KNOW I had to say that)
18-01-2005, 11:15 PM | #12 | ||
Smile
http://www.autospeed.com/cms/A_1796/article.html
I just saw this article on autospeed .It says vy ss 5.7 0-100 in 6.7 seconds, so I do believe my tips will upset many ss commodores by mums AU taxi!!! |
18-01-2005, 11:28 PM | #13 | ||
JMM is all you need to know. They rock.
AUIII XR6 VCT - Venom Red Modified JMM DEV1 VCT:- JMM Race headers, Redback cat back 2.5” exhaust, JMM hi flow cat, Modified airbox with pod filter & XR8 snorkel (JMM VCT Kit) 160rwkw |
18-01-2005, 11:39 PM | #14 | ||
ooga-lagga-ligga-lagga
u have tried advancing the cam i assume? have u advanced it as much as u can go, test drive, back it off, test drive etc. till u get the best results?
19-01-2005, 12:22 AM | #15 | ||
Smile
Nup! not yet but I will try it,or get someone who knows to try it.Thanks for tip
19-01-2005, 12:39 AM | #16 | ||
advancing the cam pretty much moves the powerband lower in the rev range. so just say u had power 2000-6000 advancing the cam a bit might move the power band 1500-5500. thats basically the go.
19-01-2005, 07:44 AM | #17 | |||
19-01-2005, 12:30 PM | #18 | |||
19-01-2005, 01:04 PM | #19 | ||
Just have a look at www.shiftkits.com.au
They have a bit of info on them there.
21-01-2005, 01:01 AM | #20 | ||
[QUOTE=useless]I have raced 20 odd ss commodores on the street and none of them beat me from 0-100 .
Ok i'm gunna bite, Can you tell me the mods that you were/are running to keep up with vy/z SS commys. I have a very healthy xr6 that wont get near a vz SS auto or manual to 100kph. so you are obviously talkin more than extractors and CAI. I had a run with a VY SS of the lights about 1 month ago and it wasn't even close he left me straight from the start and just kept on pullin away. When i get chipped and a dev 3HL cam kit I might be able to stay with one MAYBE
21-01-2005, 08:48 AM | #21 | |||
Smile
[QUOTE=our_blue_xr6]
1/ Jim Mock race series extractors 2/ lukely 2 1/2 inch cat back sports exhaust. 2/ 2 1/2 inch sports catalytic converter. 3/ K &N airfilter 4/ Iridium spark plugs 5/ Shift kit. 6/ and...my 100 kgs of tools. One last thing that I must say is the inclusion of my cam has made it slower at this speed Above 100 kmph the ss would pull away and I could not keep up. I have had 2 standard engines in the car and both responded the same way .So there is consistency. The xr6 cam typically has more lift in the intake(6.7MM) than intake (6.4MM)than exhaust. tThe standard AU six cam has 6.4 mm intake lift and 6.7 mm on exhaust. I think this may have something to do with this. One other thing too I was taken for a drive in a wrx sti last week and the performance form 0-80/90 was pretty close if not less than the AU six. After that speed I though I slid to the floor and said my prayers. Last edited by Stav; 23-01-2005 at 04:47 PM. |
21-01-2005, 01:23 PM | #22 | ||
So you've done no driveline work? What gears do you have? The stock 3.08? Thats a good effort.
AUIII Falcon Forte, with SIX Appeal |
21-01-2005, 02:39 PM | #23 | ||
FTF Club Moderator
Who installs shift kits. The ones on www.shiftkits.com.au are mail order only.
I still wonder how it reduces wear? |
21-01-2005, 02:46 PM | #24 | ||
they call me Tibbo
Best bang for buck is to throw out the 3.08 SS and whack in some 3.7's. Around $1100 drive in drive out... Even a stock i6 will be very lively at street speeds upto 100 km/h with the 3.7 rear end
21-01-2005, 04:03 PM | #25 | ||
Your local mechanic could install a shift kit for you. But it's just soldering a couple of wires together.
An automatic transmission, when it changes gears there is a lot of clutch action to make it smooth, and not harsh. By making the changes quick, the contact isn't much so it's supposed to last longer. Although I'd imagine a fair bit of heat builds up, so a tranny cooler would be wise. I might look at getting a new diff before Heathcote.
21-01-2005, 08:34 PM | #26 | |||
1998 Subaru Impreza WRX STI 0 - 100kph = 4.6secs , standing1/4mile 13.3 secs I know you love your ford mate and so do I but cmon
22-01-2005, 06:14 PM | #27 | |||
Burnin Rubber
With all these mods, is fuel economy compromised significantly?
Also, any of you know how these mods would effect a LPG AU? i suppose in most respects, better preformance, but again, what about economy?
2001 AUII Forte (LPG) K&N Air Filter Tickford Air Intake ***Coming Soon: Clear Side Repeaters*** Quote:
23-01-2005, 02:35 PM | #28 | |||
Smile
23-01-2005, 02:37 PM | #29 | |||
Smile
Ok maybe the guy in the car did not want to fang it to 100 kmph but the ss story is correct. But in that car on that day 0-100 didnt feel so great. Last edited by Stav; 23-01-2005 at 02:38 PM. |
23-01-2005, 03:53 PM | #30 | ||
not here much anymore
Don't wagons have 3.45 or 3.23 gears though? Im pretty sure only sedans got 3.08, Fairmonts got 3.45 yay! :newangel:
RAM 1500
