Old 26-03-2025, 06:11 PM   #1
Krish
Question Codes: P07A3 and P2872
Hi all, please see attached pictures. what these codes for? What are the solutions to fix it?
Thanks.
Krish is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2025, 10:56 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Default Re: Codes: P07A3 and P2872
You've not said what model Focus or even which transmission so you are just going to get a generic assessment.
P07A3 is either a sticking clutch fork on a manual transmission or a transmission friction element stuck in the on position with auto trans.
P2872 is for a stuck clutch pack on an auto and likely caused by the one above.
Give us more details and we'll try and help.
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2025, 02:21 PM   #3
Krish
Its Ford Focus 2012 LW DCT 1.6 Petrol Sedan car.
Old 28-03-2025, 12:56 PM   #4
russellw
russellw's Avatar
That would be the 6DCT250. Clear the DTCs and if they return then:
P07A3: Transmission Friction Element A Stuck On.INSPECT the clutch spring and clutch for wear or damage.
P2872: Clutch A Stuck Engaged
Refer to Section 301b in the LW WSM which we have in our technical portal for instructions.
The usual cause seems to be that the clutch fork inside the transmission gets clogged up with clutch dust and can be cleaned and lubed to resolve the issue. There is a YouTube video on how to do it HERE.
Old 28-03-2025, 09:16 PM   #5
Krish
Thanks
