Old 15-12-2024, 11:03 AM   #1
AndyT
Default Ford Rocket (Type E) gearbox in Mk1 3000GT
Hi guys, I am in the process of acquiring a 1970Mk1 3000GT automatic. I'd like to get it back on the road without too much hassle. Its missing a flexplate which I could probably source but alternatively I have seen a Type E box from Escort RS2000. Would this slip in without too much trouble? I am aware that most owners prefer the Tremec 5 speeds but that is probably a project for the future. I'm looking for minimum work at this stage. Any ideas. Thanks in advance.
AndyT is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2024, 12:45 PM   #2
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
Default Re: Ford Rocket (Type E) gearbox in Mk1 3000GT
as you are in Adelaide, I'd strongly suggest talking to Taff. I think he's back in Wales now, but should be able to help on his return
https://taffsautorepairs.wixsite.com/lyn-james
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2024, 08:47 AM   #3
gtv6capri
Hi the Type E box will not hold up, ideally you need a Type 5 but these are hard to find in Australia. The V6 Capri in manual form used the Type F ( poss also known as Type J??) which was an external shift box that looks like a "Top Loader". There are plenty around as they were a heavy old lump that did not break often. You can use the Type 9 (5 speed) but you will need to find a V4 bellhousing to mate it to a V6.
The Auto used a Spiggot bush you will need to take out and replace with a bearing (I have these). You will also need to source a Flywheel which should not be too hard, clutches are still available new. Dont forget you will need a clutch and brake pedal.
Good news is there is no difference in the diff ratio between auto and manual so you can leave it (no difference in transmission tunnel either-although I have seen the crossmember bolts sometimes differ between the two
gtv6capri is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2024, 10:00 PM   #4
AndyT
Great thanks for the information.
Old 23-12-2024, 12:03 AM   #5
cosworthfreak
cosworthfreak's Avatar
You might find someone selling the parts for a celica 5sp conversion, that’s another option.
cosworthfreak is offline   Reply With Quote Multi-Quote with this Post
