25-05-2023, 12:00 PM | #1 | ||
AU-XR8-302
Does anyone know if the standard Falcon/Fairmont Perspects instrument cover is the same as the Tickford plastic covers???
My cluster is fine, but all the plastic clips on the perspects are broken. Its cheap to buy a standard cluster and replace the plastic cover if they are interchangable? Tony. Last edited by avisionit; 25-05-2023 at 12:09 PM. |
25-05-2023, 12:19 PM | #2 | ||
#neuteredlyfe
The perspex cover will fit in terms of fitting over the cluster itself.
The problem you run into will be the odometer reset button is positioned differently. |
25-05-2023, 12:22 PM | #3 | ||
AU-XR8-302
25-05-2023, 01:14 PM | #4 | ||
Fairmont Ghia and Fairlane Ghia plastic cover will fit tickford cluster. Anything else won't as per what PG2 said.
Proud owner of the ugliest Ford ever made |
27-05-2023, 01:24 PM | #5 | |||
AU-XR8-302
Thank you. |
