Old 07-12-2022, 06:47 PM   #1
Matt_MK2
Default MK2 Cortina Chassis number decode
Hi All I have a MK2 2 door that the ID plate is missing. I have the body number CM23651B (pretty sure this is correct). Can anyone assist with identification. Thanks Matt
Matt_MK2 is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2022, 10:18 PM   #2
Capriman
formerly ford3000gt
Capriman's Avatar
Default Re: MK2 Cortina Chassis number decode
I'd suggest that that is an engine number, but the C would have to be a G for 1967, with the M being the month, which I don't know off the top of my head.
Current ride:
'83 Mk.3 Capri, 2.8i, 5-spd
Capriman is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2022, 11:41 AM   #3
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
https://www.enfostuff.com/cortina-mk...ification.html
CM would be a paint code - Alpine Green
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2022, 02:17 PM   #4
Capriman
formerly ford3000gt
Capriman's Avatar
But, all those codes are applicable to the USA! Every country seems to use their own set of numbers and letters from what I've seen and know.
Current ride:
Old 13-12-2022, 10:19 AM   #5
Matt_MK2
It is stamped into the right hand strut tower. The letter and number sequence matches my series 2 GT, but it starts with CN. I have attached a pic of the number on my original post. Thanks for the replies.
Matt
Old 19-12-2022, 07:43 PM   #6
chappy60
Thats the engine number on the strut tower cm was
a standard engine cn a gt engine the number you
need is on the radiator support panel
chappy60 is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2022, 05:53 PM   #7
Matt_MK2
Thanks chappy60, You learn something new every day. I looked on the radiator support panel first, but didn't see it. I will have a better look and see if I can find it. Thanks Matt
Old 21-12-2022, 05:13 PM   #8
chappy60
standing at the front of the car it will be to
the right of the bonnet catch on rare occasions
you might have to unscrew the grill on top and
pull it back a bit to see it
Old 30-01-2023, 03:43 PM   #9
Matt_MK2
So it turns out the radiator support panel has previously been replaced. The replacement panel didn't get the body number stamped into it. Any suggestions on what I can do for a body number when it comes time to register it (in QLD)?
Old 31-01-2023, 09:55 AM   #10
Capriman
formerly ford3000gt
Capriman's Avatar
Perhaps just check with the registration authority, Queensland Transport, as they are the responsible authority in your State!
Current ride:
Old 01-02-2023, 12:30 PM   #11
chappy60
if you have the old rego put it into the qld
rego app you might get lucky with a cm
engine number sounds like its around a 68 model
was the car ever on club rego
Old 01-02-2023, 05:17 PM   #12
Matt_MK2
I don't have any previous rego details unfortunately. I purchased it as a rolling body along with a heap of GT parts from south of Sydney about 7 years ago. I was thinking maybe a late 68 or 69, as it's a series 2 but had the smaller id plate on the inner wing. I will go into the local Ford dealer here in Toowoomba with the engine number and see if they can find any details.
Thanks for the replies, Matt
