Old 06-03-2021, 07:56 PM   #1
pete r
Default Tickford-Yella Terra Heads
I though this may be on interest...
I managed to pick up a couple of heads from a Tickford TE50. Apparently they’re the same as the 220kW heads, ie larger valves, ported by Perfectune/Yella Terra.
Today I put them on the bench and lined them up with a standard intake manifold. It’s an interesting comparison.
I’ll now use bearing blue to show where to mod the intake manifold and then break out the old CC Specialty porting gear from my bike racing days!
Manifold ports vs head ports -
http://
http://
Milling to reduce shrouding around larger inlet valve -
http://
The Yella Terra milling/porting is easy to see when compared to the normal combustion chamber casting -
http://
pete r is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2021, 08:50 PM   #2
XC50077
Drive'n Cruise'n Live'n
XC50077's Avatar
Default Re: Tickford-Yella Terra Heads
Great Pics,
Are intake and exhaust valve retainers and keepers the same?
XC50077 is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2021, 04:00 PM   #3
pete r
Looks that way...
Old 04-05-2021, 04:13 PM   #4
pete r
TE50 heads fitted with YT roller rockers and ported lower intake. The rockers are adjustable and 1.7:1 ratio. The only issue is the standard rocker covers won't fit...
Old 04-05-2021, 04:18 PM   #5
pete r
A quick trip over to Campbelltown and Sydney Speed Supplies for some spiffy tall valve covers -
Old 04-05-2021, 04:19 PM   #6
pete r
The upper intake looked daggy as **** so a touch of Brand New was added -
Old 04-05-2021, 04:24 PM   #7
pete r
A 1" intake spacer was required because of the added height of the new rocker covers. And here she is in all her glory!
Old 04-05-2021, 04:35 PM   #8
pete r
It's a totally different beast now. Snappy as fook. Exhaust note is totally different, engine seems to have lost a little bit of bottom end but wants to spin like a top.
Must be because of the increase in rocker ratio increasing lift, valve opening and closing speeds and 50thou duration. Bigger valves, increased compression and ported lower intake obviously contributing too.
Off to the dyno next week for a before and after comparison. Then once I figure out Quarterhorse and get it tuned properly then a final dyno reading. The poor old ECU doesn't know WTF has happened!
Old 13-05-2021, 11:48 AM   #9
pete r
Before and after dyno results. I couldn’t ask for a better result, no loss of bottom end power, AFR ratio still good and open for tweaking at the top end. And it’s all Ford bits. 250rwhp must be 300+fwhp?
Old 13-05-2021, 11:53 AM   #10
pete r
Old 13-05-2021, 11:55 AM   #11
pete r
Pic is cropped. Bugga!
Old 13-05-2021, 03:35 PM   #12
pete r
Here we go - isn't that the loveliest curve? All gain, no loss
Old 13-05-2021, 04:43 PM   #13
pete r
Old 13-05-2021, 05:14 PM   #14
pete r
Couldn't get the youtube thingy to work so here's the raw link to the car on the dyno if you want a listen -
https://youtu.be/mAj0swgqVLQ
Old 13-05-2021, 05:35 PM   #15
GasoLane
Former BTIKD
GasoLane's Avatar
Here ya go.....
Originally Posted by pete r View Post
Old 13-05-2021, 05:36 PM   #16
speedzter
Interesting how both curves flatten off around 4500 rpm.
it also appears to go fairly rich at the same point.
speedzter is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2021, 07:39 PM   #17
TICKFORD220
2009 xr turbo,2004 fiesta
Almost identical power to my old 220kw s3 manual,mine had stock 220 headers,twin manta system,ported lower intake,msd coil packs, advanced cam timing by 2 degrees,made 255 rwhp.
My timing chain was stretched and fkd after 100000km so i replaced with a rollmaster and advanced timing to make it a bit snappier down low.
Mine got tuned by chad at streetbuilt.
Good result there cobber.
TICKFORD220 is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2021, 01:16 AM   #18
pete r
Originally Posted by GasoLane View Post
Here ya go.....
You champ thanks Gaso
Old 14-05-2021, 01:22 AM   #19
pete r
Yeah interesting aye. I’ve got the quarterhorse talking to the ECU and the laptop, and have some O2 sensor bungs ready to weld onto the exhaust. When it’s all connected I’ll see what the wideband says it’s doing and maybe try leaning things out a wee bit, see if the AFR can be a bit more linear. There might be a few more ponies hiding in there...
Old 14-05-2021, 01:25 AM   #20
pete r
Cheers digger!
Did the stretched timing chain make any noise at all?
Old 14-05-2021, 06:38 PM   #21
LoBelly
Thanks for this update - have recently acquired a '99 XR8 myself and am contemplating my options (also have some of the Tickford 220kw/GT40P heads on my shelf)
Having read Stu's posts on the quarterhorse I'm keen to give that a go
sound like you're very satisfied - would be keen to hear how you go with the tuning etc
LoBelly is online now   Reply With Quote Multi-Quote with this Post
Old 15-05-2021, 04:42 PM   #22
pete r
No worries mate, I’m starting from scratch and will keep you updated!
Old 15-05-2021, 05:03 PM   #23
TICKFORD220
Cheers digger!
Not at all,i planned to advance the timing so i got a new timing set,once it came apart i found the the factory chain was rooted.
Old 17-05-2021, 06:56 PM   #24
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Very typical of a factory tune. I was seeing my AFRs on my stock P250 dip down into the 10s.
Good work Pete. Very interested in following your progress.
I have started a EECV/QH tuning thread. It may help you. Have a read, and if you have any tuning questions, post them there and I will happily assist if I can.
https://fordforums.com.au/showthread.php?t=11478284
Good luck.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2021, 07:38 PM   #25
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Quoting myself, apologies.
Here is a graph I logged of the factory tune in my P250. Factory tune commands stupid rich high in the rev range. Graph uses lambda not AFR on the right scale. Lambda X 14.64 = AFR. Follow the black line.
Same graph with fuelling corrected (2nd gear pull) - again follow the black line.
Stu
2002 AU II LTD
