HUGH JARSE
![]() Join Date: May 2005
Can anyone enlighten me on what this black plastic thingy does?
My guess is that it stabilises the AU at speed. ![]() |
#2 | |||
![]() Join Date: Oct 2006
Bumper apron or valance. As they say at: https://www.carid.com/articles/what-...r-valance.html
regards Blue |
Is that on the trailing edge of the wheel arch ??? If so, it's probably just a glorified rain/dust spat that utilises the disrupted air flow to keep crap away from the side of the car.
HUGH JARSE
I assumed from the pic I posted that it would be clear as to where on the AU the 'thingy' is located.
These are on the front mudguards. |
HUGH JARSE
I think these are better pics to show their size and location on the front mudguards
#6 | |||
regards Blue |
Hardly a mystery, unless you live under a rock or are a flat-earther or something
![]() They are to satisfy ADR requirements wrt wheel coverage (as you well know). Also found on many imports, until discerning owners rip the ugly things off ![]() Why they would be required on an AU Falcon/Fairmont/Fairlane etc (solely designed for the domestic market) makes you wonder if the designers had ever consulted the local regulations ![]() AU's ![]() .
. Last edited by Raptor; 14-01-2019 at 02:32 PM. |
But they are also still there to keep the bodywork clean especially if they are aftermarket rather than factory e.g. https://www.adamesh.co.uk/jaguar-x15...ats-4721-p.asp
regards Blue |
HUGH JARSE
Thanks Raptor but I have my doubts.
The hint is in the design - see how they are formed to slice through the air? I did a search, but I came up empty. Maybe I missed something. A comparison of airflow would settle it once and for all. |
#10 | |||
You can't stop the signal
What Raptor said.
My memory says added on AU2 onward. Still see them on many imports. As to why my guess is late regulation change or unknown implementation. With where they are it would knock into the guards and the front bumper to change. Too much tooling money when the small add on fixes it.
#11 | |||
![]() ![]() Join Date: Jun 2006
#12 | |||
Sorry Cav, I thought you'd left the lens cap in the way.....again ;-)
Steve Current rides 2012 Mondeo Titanium wagon (TDCI) Moondust silver 2016 Focus Trend, 1.5ecoboost, 6sp manual. Frozen white Previous 2004 Berlina Wagon (LS1) Vespers Blue 1995 Camry 2.2, white 1971 Ford Fairmont wagon 302w, C4 Polar white 1971 TC Cortina, 2L 4sp, Ermine white |
HUGH JARSE
#14 | ||
Nah; their real secret purpose is to trap water between them and the guards to promote rust so you have to buy a new Falcon earlier than otherwise may have been the case.
regards Blue |
#15 | |||
🚫⏰4️⃣🐃💩
It was added to satisfy ADR regulations after a design oversight by FoMoCo Australia. You will find these "black plastic things" on ALL AU's (AU1, AU2 and AU3) fitted with the 17" (or 18") Tickford wheels and suspension (either optioned or standard fitment) and 235 wide tyres. Wasn't just a AU2/AU3 thing either. AU1 Tickford cars such as the XR's and T-Series had them. Even a AU1 Forte would have them if it was optioned up with 17" Tickford wheels and suspension. The quick and simple explanation is, when the 17" or 18" wheels with 235 tyres were fitted to the AU, the front edge of the wheel and tyre were slightly visible from a direct top view, making the vehicle uncompliant to ADR's. A quick solution was designed and implemented by using these "plastic thingy's". Wonder how many AU's that came factory fitted with 17"/18" wheels and 235 wide tyres still have them on? There would be many AU's out there that have had them come off, or removed by now. Making them non-compliant to ADR's. Again, not a rain deflector, nothing to do with dust, aero, or slicing through the air, etc. The AU was a simple car. Please don't overcomplicate it. ![]() edit: Read through this thread from the start.... oh boy.... ![]() Last edited by Tickford.; 14-01-2019 at 07:50 PM. |
#16 | ||
HUGH JARSE
So, are youse blokes saying that if the plastic thingies on 17 inch AUs (and above) are missing then it is a fail for roadworthy?
#17 | |||
If like most old Falcons the front springs will have sagged, the balljoints are going and the bushes are stuffed. This fail safe will have the front end adopting some negative camber and the tops of the tyres should be tucked under the guards no probs ![]() .
#19 | ||
HUGH JARSE
3 users like this post: |
#20 | |||
HUGH JARSE
Even if the top were tucked in as you say, what about the bottom? Surely as you say the 'black thingy' is to meet design rules, then the bottom of the tyre will still protrude as much as it ever did. I think you have a closed mind on this Raptor and are unwilling to look at credible alternatives such as wind deflection. If what you profess, that the 'black thingy' is needed to meet Australian design rules, then those AUs with 17 inch or larger wheels must be defective. No? Except for the ones with stuffed suspension. |
#21 | ||
Former BTIKD
![]() Join Date: Mar 2005
Could it be an aerodynamic design to help lift the front to compensate for overweight drivers?
#22 | |||
The Terrain Tamer
![]() ![]() Join Date: May 2013
![]() Was it an optional extra... ![]()
Current Ride : A Ford owned D3... |
5 users like this post: |
#23 | ||
Looking for clues...
Perhaps it was a stiffener, to strengthen the guard for when portly gentlemen owners non-nonchalantly lean against it, while telling of how they managed to acquire their fine steed.
2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra - Build Thread 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them |
#24 | ||
HUGH JARSE
It certainly is a weighty issue folks.
#25 | ||
I always thought black plastic thingies were always battery operated, rocket shaped and it was forbidden to ask what they were for.
regards Blue |
#26 | ||||
For roadworthy, my memory says top portion of tyre tread must be under guard from above. Hence stretched tyres are legal. Best example is on exhausts. ADR has static & drive by noise levels. Road worthy only cares about static test, hence can be louder.
#27 | ||
HUGH JARSE
#28 | |||
HUGH JARSE
#29 | |||||
You're good.
Reading below there is some ambiguity in the roadworthy (VSI), but general consensus I'm aware of is when viewed from above ADR 42 Quote:
#30 | |||
Next upgraded Mk1 Leopard
UK
