25-11-2017, 05:40 PM | #1 | ||
Tippy-tronic Free Zone
Ford Radiator Upper Bracket 1381666 - holds the top of the radiator to the support panel and stops it flappin around.
Went to fill the washer bottle today and noted its absence. Anyone know where I can get one? Or I can call Ford OZ on Monday and see what they have. Thanks |
25-11-2017, 07:35 PM | #2 | ||
Challenge Accepted!
wreckers would be your best bet.
<off topic> A neighbour near my folks came over to have a chat (sticky beak more like it) when I was working on my timingbelt+WP he had broken his but still had the top part. wanted to know where to get one, but I have a range of bolts/nuts ect. so I dropped a suitable bolt through the top and nut from the bottom then used electrical tape to make a taper around the bolt worked like a charm he said. you'll see what I mean:
25-11-2017, 08:37 PM | #3 | ||
Challenge Accepted!
oh! just thought of it, tried checking in front and behind the radiator in case it's dropped inside and still there?
26-11-2017, 01:45 AM | #4 | ||
If your referring to part 8A193 from the catalogue below, it has a Ford Part number of 6G91 8A194 EB and around $8 each from Ford. They are all the same for MA MB MC Mondeo with every engine combination.
MB Radiator.pdf |
26-11-2017, 10:01 PM | #5 | ||
GTLegend - that's the one.
Cobrin - I did look but it is terribly full down there !!!! Don't want to pull lots out for no result. And I also found your pic on the net. Thanks everyone |
