Old 25-10-2016, 08:11 AM   #1
cruza
Default Stiff Steering Mk2 Cortina
Hi to all, my mk2 cortina has steering that feels heavy, wont center after going around corners left or right, I thought it was the steering box so i changed that with another one. The replacement box felt nice and smooth when not connected to the drag link, but there is still the non centering issue when connected and driven, so i had the alignment done and still no change....Do the shockies have a bearing at the pivot point on the struts? I have even changed the front tyres thinking they might have something to do with it. I'm hoping someone can shed a bit of light on this as it makes the car drive like a pig.
cruza is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2016, 08:32 AM   #2
foxtrot3
foxtrot3's Avatar
Default Re: Stiff Steering Mk2 Cortina
Hi. Might pay to check the lower ball joints, might find one of them is seized. Dont think they had a bearing in the top plate but unless there is a massive amount of rust on the shocker shaft it wont be any harder to turn there than it was when it left the factory. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2016, 08:47 AM   #3
cruza
ok thanks, i never thought about the ball joints
Old 25-10-2016, 08:34 PM   #4
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Might be a mk1 drag link. Had the same issue with my mk1, turned out it had a mk2 link in it... may be the other way around in your case...
Escort RS2000 Restored factory a/c and alloys.
TD Cortina Unrestored 35 000km 6cyl manual.
Mk1 GT Cortina Project.
FG XR50 Daily.
Rallye Sport is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2016, 10:42 PM   #5
yearby
Most, not all mk 2 Cortina's had a rubber mount at the top on the suspension strut which flexed when the steering wheel was turned. That is the rubber distorted when turning and the rubber would return to it's original position when the steering wheel was released, thus centralising the steering. If the rubber joint has deteriorated, or some one has fitted it wrong, or put a left side one in the right side for instance, it would cause havoc with your steering.
Peter
yearby is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2016, 09:16 AM   #6
chappy60
I would hazard a guess and say it would be the drag link bushes had the
same problem some years ago the originals are hard nylon when they supply
new bushes they are polyurethane or nolathane these I found had problem
gripping the drag link pin that went through them e.g. heavy steering and
steering not centralising replaced with the original type bush and the problem was
solved
chappy60 is offline   Reply With Quote Multi-Quote with this Post
