Old 26-07-2016, 03:40 PM   #1
XCH00N
XCH00N's Avatar
Default Engineer in WA
Hi all,
I'm just wondering what good engineers there are here in WA I would prefer Kalgoorlie or close to but know most likely ill need to go to Perth. Just need to start talking to one about my F100 which I'm turboing a 250xflow for and just wanna see what else they will want done.
Cheers Brad
THE SHED
Daily - BA Mk2 XR6 Turbo, Auto on 20s
Long Term Project - XB Sedan, too much to do on this one But its a 351, 4speed with a LSD 9inch (Back over home in NSW)
XCH00N is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2016, 05:24 PM   #2
wodahs
wodahs's Avatar
Default Re: Engineer in WA
HOOVER, Jack
Hoover Industries
PO Box 63
KALGOORLIE WA 6433
(08)9093 3132
0400 222 552
LV
Jack.hoover@hoover-industries.com
second last on the dept of trans web site page http://www.transport.wa.gov.au/media..._VS_IB_102.pdf
but you wont need them just make application to dept of transport to modify engine in such a way and they SHOULD give permission if they do then no mod needed if they don't then now way getting passed
I went thru this some time ago for my zh fairlane and would be allowed to force induct a motor of up to 5.4 (from memory) ci but im running larger 6.6cc's to be closer
its calculated off vehicle mass and anything with mass over 1100kg its 3 times that weight equals the largest cc's motor you can apply for
read under section 2.13 ENGINE CAPACITY
https://infrastructure.gov.au/roads/...jan2011_v3.pdf
from memory application form to fill out is ib-102q
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2016, 05:27 PM   #3
wodahs
wodahs's Avatar
heres the application form
http://www.transport.wa.gov.au/media...htVehicles.pdf
Old 28-07-2016, 12:40 AM   #4
wodahs
wodahs's Avatar
so how'd you go ?
