Old 12-06-2016, 10:36 AM   #1
OzriderXR8
OzriderXR8's Avatar
Default AUII XR8 200kw - Torque Increase
Hi All
I'm sure it's in here somewhere......
What would be a recommendation on increasing torque on the XR8, I'm not fussed about top end or anything else I can't actually use.
Car is not a daily driver but I still want to be able to drive to Adelaide or similar without ruining the national economy.
So far as far as I know everything is pretty stock with an auto, all it has is a Redback cold air intake and a Redback 2.5" Cat Back single exhaust.
I'm not looking at engine surgery, just economic bolt on type stuff.
Any ideas?
Cheers Ozrider
AUII XR8 200KW
FG MK2 XR6
Mini 850
Rover P5 3 Litre Mk1
OzriderXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2016, 02:43 PM   #2
madmelon
Default Re: AUII XR8 200kw - Torque Increase
Hurricane 4-2-1 Headers
If you want new cats/don't care about emissions compliance, get some 100CPI metal cats and put them about 300-400mm behind where the collector merges on the headers
A single 2.5" exhaust might be a bit of a restriction. Single 3" probably better and twin 2.5" better again. (I've got the twin 2.5" and it sounds unreal)
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2016, 03:02 PM   #3
Blue Shadow
R.I.P. Maggie
Blue Shadow's Avatar
OZ, would you want to go down the chip path? I've been thinking of doing it.
AUII XR8 200Kw Ute
FG XR6T
1976 289 Mustang (Gone)
Blue Shadow is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2016, 05:47 PM   #4
Bossxr8
Peter Car
Bossxr8's Avatar
Lower diff gears are the best way.
Old 12-06-2016, 05:48 PM   #5
Blue Shadow
R.I.P. Maggie
What ratio diff in a ute?
AUII XR8 200Kw Ute
FG XR6T
Old 12-06-2016, 05:58 PM   #6
Bossxr8
Peter Car
Bossxr8's Avatar
Depends if auto or manual i guess. Auto i would say 3.9 or 4.1.
Old 12-06-2016, 06:00 PM   #7
Blue Shadow
R.I.P. Maggie
Thanks Boss, will I only need to buy the guts of the diff or a whole new one i.e axles
AUII XR8 200Kw Ute
FG XR6T
Old 12-06-2016, 06:01 PM   #8
Bossxr8
Peter Car
Bossxr8's Avatar
Just the ring gear and pinion.
Old 12-06-2016, 06:42 PM   #9
inventiv
inventiv's Avatar
What about the 70mm throttle body from a 220kw engine?
inventiv is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2016, 09:31 PM   #10
OzriderXR8
OzriderXR8's Avatar
All great suggestions but all have a heap of conflicting info re benefits.
I've chipped a couple of bikes and you get the performance but usually at the expense of fuel. No real performance, just different fuel mapping.
If I change the diff ratio I get better acceleration but loose cruising economy.
I guess I'm looking for the old style carb type thing with 2 barrels until you put your foot down and open the secondaries. Vtec style....
Cheers Ozrider
AUII XR8 200KW
FG MK2 XR6
Mini 850
Old 12-06-2016, 09:35 PM   #11
mcfly94
mcfly94's Avatar
Get it tuned, youll notice a difference, chuck some 3.9's in its not that bad.
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2016, 09:42 PM   #12
Strattos
Strattos's Avatar
Re the diff gears, I haven't done it myself, but have read other threads where there wasn't necessarily a heap of difference in fuel economy, or not enough that it didn't justify the torque gains in lowering the gearing, depending on how low you go of course.
Current: 2000 AUII XR8 manual ute.
1966 XP Pursuit ute.
2012 Honda Euro manual (daily drive)
Past: 1984 XE Falcon sedan 4.1L.
Strattos is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2016, 09:46 PM   #13
LyleXR8
Diff gears are already good in an AU XR, my manual is well over 2,000rpm at 120, can put a normal falcon diff in to lower revs, dunno how it effects economy or torque though
LyleXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2016, 12:55 AM   #14
T MAN
T MAN's Avatar
diff gears are a good start, gives it a more lively feel, i run 3.91 gear and its no different on fuel as you dont need to load it up as much to get to the speed limit, rpm at 110 isnt to bad at 2500rpm at 110 kmh..
if you want to go for the tunning route can get nice down low torque improvement from a couple of degrees of timing and depending on what or who tunes it, the ecu actually has torque reduction strategies in the ecu that reduce timing under hard load in 1st gear to prevent trans damage, removing these functions make nice improvements...
T MAN is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2016, 09:40 PM   #15
Bossxr8
Peter Car
Bossxr8's Avatar
I got better economy around town with 3.9's, and made hardly any difference on the highway. Not enough to make much of a difference anyway.
Old 13-06-2016, 09:45 PM   #16
mcfly94
mcfly94's Avatar
i will own up to fuel economy going down, 3.9's went and foot went further to the floor, now averages 19.6l/100km around town (stock car mind you)
Old 13-06-2016, 09:48 PM   #17
Blue Shadow
R.I.P. Maggie
What did you get from a stock diff?
AUII XR8 200Kw Ute
FG XR6T
Old 13-06-2016, 09:58 PM   #18
mcfly94
mcfly94's Avatar
Was averaging around 14.7ish
Old 13-06-2016, 09:59 PM   #19
Blue Shadow
R.I.P. Maggie
Big jump
AUII XR8 200Kw Ute
FG XR6T
Old 13-06-2016, 10:05 PM   #20
mcfly94
mcfly94's Avatar
Big jump
yeah i do a lot of short drives, and definitely drive it harder since having them in there.
Old 13-06-2016, 10:10 PM   #21
Blue Shadow
R.I.P. Maggie
I do mostly long drives, its not a daily but I go up to Hervey Bay & Bundy most weekends, so it might be worth a crack for me with 3.9 or 4.1. Just gotta find them, how much new would it cost?
AUII XR8 200Kw Ute
FG XR6T
Old 13-06-2016, 10:25 PM   #22
mcfly94
mcfly94's Avatar
my gears were about $600 new iirc and then $500 fitted with new bearings
Old 13-06-2016, 10:27 PM   #23
Blue Shadow
R.I.P. Maggie
Thats not to bad if you get some extra torque out of it
AUII XR8 200Kw Ute
FG XR6T
Old 13-06-2016, 10:32 PM   #24
mcfly94
mcfly94's Avatar
definitely, need one of those 'frequently side ways stickers', gears and removing the torque reduction strategies and adding some timing down low made a huge difference!
Old 13-06-2016, 10:33 PM   #25
Blue Shadow
R.I.P. Maggie
Just get it tunes or a J3 chip?
AUII XR8 200Kw Ute
FG XR6T
Old 13-06-2016, 11:07 PM   #26
BOTTLEDUP
Add cubic inches or a PD blower...
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2016, 07:04 AM   #27
Sox
RIP...
Sox's Avatar
Being auto, the gearing is up the poo.
3.9 or 4.1 gears will help a lot.
The standard headers are garbage, throw on some tri-Y's with 1.5" primaries, Advance or Hurricane.
The single 2.5" system will go ok as you're not chasing top end power.
Then a tune with ignition timing advanced and torque reduction removed and you'll be doing skids all over the joint.
Oval Everywhere...
Old 14-06-2016, 07:18 AM   #28
Blue Shadow
R.I.P. Maggie
Yeah, I ordered the exhaust, Advance headers, with a single and high flow cats
AUII XR8 200Kw Ute
FG XR6T
Old 25-06-2016, 11:03 AM   #29
OzriderXR8
OzriderXR8's Avatar
What revs are you guys showing at 100kph?
Mine sits on 2000rpm.
Cheers Ozrider
AUII XR8 200KW
FG MK2 XR6
Mini 850
Old 25-06-2016, 11:31 AM   #30
Blue Shadow
R.I.P. Maggie
1900 in a ute
AUII XR8 200Kw Ute
FG XR6T
