19-05-2016, 01:29 AM | #1 | ||
So, after sitting all day in the car park, when started, my daughter's car starts billowing white smoke.
However, after being idled for a while, then left to cool, and re-started, no sign of anything unusual. To me, white smoke means water (coolant) being burnt. So I'm thinking: Car driven to work, gets nice and hot, under pressure head-gasket starts to leak. When car is parked, continues to leak under pressure and builds up in cylinder. Car is started, burns off coolant and eventually purges all from exhaust. Engine turned off, not too hot, so no further leakage. Starts fine next time round. The coolant looks fine, as does the oil. The coolant level was still ok. So, with the engine cold we have topped the coolant to a precise level. Will drive the car to work, park it up, then check the level in the evening when its cold again. It's also possible that it was simply a bunch of condensation after being driven and then parked on a cold day. Am I missing anything? Any other possible culprits for white smoke? NB: It is a Nissan Tiida, with a typical, disposable, Thailand engine. So it's not improbable that the gasket or head has started to dissolve.
I can hear the Hippies crying from here. |
19-05-2016, 05:53 AM | #2 | ||
Chairman & Administrator
I think you are on the right track for the initial diagnosis although if it is using neither water or oil then it is going to be harder to diagnose.
Cheers Russ
Observatio Facta Rotae
19-05-2016, 09:40 AM | #3 | ||
Auto-trans fluid?? Pulled in via the manifold vacuum line.??
Steve Current rides 2012 Mondeo Titanium wagon (TDCI) Moondust silver 2016 Focus Trend, 1.5ecoboost, 6sp manual. Frozen white Previous 2004 Berlina Wagon (LS1) Vespers Blue 1995 Camry 2.2, white 1971 Ford Fairmont wagon 302w, C4 Polar white 1971 TC Cortina, 2L 4sp, Ermine white |
19-05-2016, 11:51 AM | #4 | ||
does it disappear quickly (water) or hang in the air for awhile (oil) -
trans. oil as mentioned by whitelion65 |
19-05-2016, 11:58 AM | #5 | ||
How cold is it out side temp? It just sounds like condensation in the exhaust as you haven't mentioned that it is hard to start or runs rough till it dissipates.
If it was a head gasket issue it would run rough and have bubbles in the cooling system .
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
19-05-2016, 12:04 PM | #6 | ||
Most likely just condensation in the exhaust system.
19-05-2016, 01:19 PM | #8 | ||
Most cars blow clouds of condensation from the exhaust on a very cold day when they are dead cold, it's only water vapour.
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
19-05-2016, 06:56 PM | #9 | |||
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's In Storage : '74 XB GS 351 Fairmont Sedan XB Falcon Owners Group Mike's Man Cave |
19-05-2016, 09:09 PM | #10 | ||
Hopefully for your self it is only just a matter of water evaporation due to the colder weather.
In saying this, and I don't mean to worry you, I once repaired a 92 Ford laser which had similar symptoms as you have described. It would blow white smoke on start up after being stationary for a while with no other symptoms of any head issues (rough idle/ running, milky engine oil, bubbles in radiator whilst running etc). Once the head was removed it definitely revealed that the head gasket was faulty so that ended up having to be replaced and finally resolved the issue. However as you have mentioned, just top up all relevant fluids and see how things go over time. If you notice that no fluids are getting low down the track then you should be fine |
21-05-2016, 02:04 AM | #11 | ||
Thanks everyone.
So far, it has impossible to substantiate any coolant loss, or replicate the problem to any significant degree. Will keep monitoring the coolant, but fingers-crossed it was just some freak confluence of weather and condensation.
21-05-2016, 12:46 PM | #12 | ||
21-05-2016, 01:01 PM | #13 | ||
BA/F6 BF/F6 SSV/R TTG
Best sell it and get her a ford.
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
