Old 18-12-2015, 11:29 AM   #1
Drecian
Default Lean cruise?
The more I read, the more 'Lean Cruise' pops up, but I can't seem to find anything as to what it does and the conditions that activate it.
Anyone have any insights?
Jeff
'99 AU1 Fairlane
Drecian is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2015, 08:19 PM   #2
Davehoos
Default Re: Lean cruise?
Originally Posted by Drecian View Post
The more I read, the more 'Lean Cruise' pops up...
Are you refer to lean fuel to air ratio?
on light throttle cruise the fuel mixture should be held mid to lean by the ECU program and sencors for the cat to work.
AU falcon is a lean burn engine.
BF11 XT EGas Wagon-SY TERRITORY AWD GHIA-
Land Rover 88
.MIDCOAST NSW.
Davehoos is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2015, 10:27 PM   #3
FNQracing
RAGE Engineering
FNQracing's Avatar
In ECU controlled engines, the fuel mixture will lean out a little (more air / less fuel) when light throttle is applied (maintain speed) in order to gain better fuel economy.
If it doesn't fit, use a BIGGER hammer
FNQracing is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2015, 12:52 PM   #4
Drecian
I see.
From the wording of what I read, I was under the impression that it was some new fandangled technology.
Guess it's just the marketing for the ECU doing what ECU's generally do for efficiency.
Jeff
'99 AU1 Fairlane
