Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 28-10-2015, 03:03 PM   #1
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default BA BF FG 328mm Rear Brake Upgrade options
We have had a lot of inquiries about the 328mm vented PBR rear upgrades which have the larger rear disc and larger rear pbr caliper on the BA BF FG model Fords and have put some packages here for you.
These kits are suitable for the rear of sedans,wagons and utes and are better paired with a 322mm or larger front brake kit.We can sell the kits less the hoses or with and also have options with RDA plain or slotted and dimpled or DBA plain,T2 or T3 rotors and many pad choices from street to strip.
Prices of the various kit combo's we do have no hoses or right up to everything from $350 up to a full complete kit for $1100.
Example of kits below
One option is to run the DBA T3 rear 328mm vented and slotted disc rotor with the red PBR caliper along with braided lines and brake pads at about $995 a kit. (this kit is pictured)
Another option is our cheapest and that is plain un slotted rear rotors with std street pads and red calipers with no hoses from $350
Available now and only whilst stock is available
$995 kit is pictured
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 20-11-2015, 12:24 PM   #2
Cable
Cable's Avatar
Default Re: BA BF FG 328mm Rear Brake Upgrade options
Hi Matt
Re. the 328 upgrade, im looking at the callipers, pads and T2 rotors. Also can I use my existing lines?
Just after a price and if you have in stock as I can pick up.
Thanks for your time
Jase
Cable is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2015, 01:49 PM   #3
FormulaFG
Lurking......
FormulaFG's Avatar
Do those calipers only come in red?
FormulaFG is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2015, 06:22 PM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Yes only red
MATTHEW PEARCE
Phone 02 9609 1101
Old 23-01-2016, 12:58 AM   #5
03 GHIA
How much would it be for the calipers, RDA dimple/slotted rotors and a decent street pad such as HPX or similar alternative posted to 2777?
Don't need lines as I've just bought and fitted a set of Goodridge brake line from you (great quality too!) I assume they would fit fine with the round banjo from the solid rear rotor caliper?
Is it a noticeably better setup? Have only recently replaced rear discs and pads in standard size, so a bit hesitant to blow more money and replace near new items. Should have gone larger at the start
Current
Viper 2010 50th Anniversary XR6T
Stock, but for how long...
Previous
White 2003 Fairmont Ghia
First- RIP.
White 1990 Ford Fairmont
Exhaust, intake, cam & lowered.
03 GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2016, 09:27 AM   #6
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Seen this so many times but can quote you.
328mm Rear RDA S/D and red pbr calipers with HPX pads and delivery to 2777 is $545
MATTHEW PEARCE
Phone 02 9609 1101
Old 08-05-2016, 08:56 AM   #7
phantom_87
phantom_87's Avatar
How much for the calipers only. I just got the 6/4 brembo kit off you for my ba but unfortunately the rear rims dont clear the brakes.
Ill keep the 4 pistons aside for my next wheel change so ill put the pbr on for now until then
445RWKW of kennebell goodness
phantom_87 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2016, 11:06 AM   #8
dead_man00124
Price with postage to 3047
Calipers braided lines pads and rda rotors?
Will b paired to 6 pot brembos
Sent from my LG-H340 using Tapatalk
dead_man00124 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2016, 12:12 PM   #9
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Should be about $720 just depends on what pad you want i only quoted std street use.
I have quoted RDA slotted and dimpled and that you car is a sedan with traction control. If you have anything different the price may change so you could spend $720 or up to $850 with freight.
Lets us know how you go with the wheels
MATTHEW PEARCE
Phone 02 9609 1101
Old 09-05-2016, 12:14 PM   #10
dead_man00124
Hi its for an AU s1 ghia so traction control& irs
Old 09-05-2016, 02:24 PM   #11
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Did you change the front end to a series 2 for the Brembo conversion ? i do not have the specs for the AU S1 rear hoses so you may need to work with me on this one and they are a little dearer.
MATTHEW PEARCE
Phone 02 9609 1101
Old 10-05-2016, 08:12 AM   #12
dead_man00124
Its s2-3 front suspension
My mate has a s2 so i can check the lines and see if they are different
Old 10-05-2016, 09:59 AM   #13
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The rear hoses on sedan and wagons and utes depending on ABS or IRS and even traction control make life making rear Ford hoses a living nightmare for me as alot of Fords were also recalled because of the hose issues they had.
I can make every Ford rear hose once we get the correct set up.
MATTHEW PEARCE
Phone 02 9609 1101
Old 30-06-2016, 07:33 PM   #14
AussieSlacker
How much for just 328mm PBR red calipers?
AussieSlacker is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2016, 12:07 PM   #15
FLOORED
Race Brakes Sydney
FLOORED's Avatar
I have a couple of red pair left @ $220 a pair thanks
MATTHEW PEARCE
Phone 02 9609 1101
Old 13-01-2017, 10:58 AM   #16
stevefreestyle
Hi Floored, Will these FG 328mm Rears fit under 17" Rims ? I have a BA XR8 with Premium Brakes (325mm Fronts).
Thanks
stevefreestyle is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2017, 11:30 AM   #17
stevefreestyle
Thanks
Sorry, correction - I meant BF XR8 328mm Rear Rotors/Calipers.
Old 14-01-2017, 09:58 AM   #18
FLOORED
Race Brakes Sydney
FLOORED's Avatar
All the 328mm rear kits are basically the same on the rear of the BF or FG just the hoses that are different and yes they fit the majority of 17" wheels.
MATTHEW PEARCE
Phone 02 9609 1101
Old 14-01-2017, 08:31 PM   #19
stevefreestyle
Thanks, Do you have any calipers in stock for the 328mm rears (assuming the fit my BA XR8 stock 17" rims), and price please.
Old 16-01-2017, 09:48 AM   #20
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Yes we do have a set left and these ones are $240 a pair at the moment.
MATTHEW PEARCE
Phone 02 9609 1101
Old 16-01-2017, 10:51 AM   #21
stevefreestyle
Thanks Mathew, I will give you a call.
Cheers, Steve
Old 16-01-2017, 01:35 PM   #22
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Cheers, Steve
Not a problem or a pm is ok as well
MATTHEW PEARCE
Phone 02 9609 1101
Old 26-04-2017, 02:52 PM   #23
5LXHR8
5LXHR8's Avatar
Any of these campers left?
Sent from my iPhone using Tapatalk
Regards
5LXHR8
Daily- AU 2 Fairmont Wagon V8
Toys- T3 TS50 build 211
- 67 XR ute
5LXHR8 is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2017, 04:57 PM   #24
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Yes i have a set available.
MATTHEW PEARCE
Phone 02 9609 1101
Old 26-04-2017, 05:03 PM   #25
5LXHR8
5LXHR8's Avatar
And if I've got this correct I'll need a set of 328mm rotors to use or can I use these with my standard brakes on my series 1 BF? And will they fit the braided brake lines I just ordered through you via phone an hr ago?
Regards
5LXHR8
- 67 XR ute
Old 05-07-2017, 11:02 PM   #26
MR_FG_09
Hi im after the full kit of T3 rotors, PBR calipers, pads & braided lines any kits available
Sent from my SM-A520F using Tapatalk
MR_FG_09 is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2017, 09:40 AM   #27
FLOORED
Race Brakes Sydney
FLOORED's Avatar
So the complete rear 328mm kit only and is it for a BA BF FG sedan or ute with or without traction control thankyou.
MATTHEW PEARCE
Phone 02 9609 1101
Old 06-07-2017, 03:39 PM   #28
MR_FG_09
Sorry mate FG sedan with traction control
Old 06-07-2017, 06:00 PM   #29
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Can do a complete rear kit for $825
Will have
Red 328mm pbr rear calipers x 2
DBA T3 rear rotors x 2
Wagner rear brake pads
Braided rear brake lines.
MATTHEW PEARCE
Phone 02 9609 1101
Old 06-07-2017, 07:31 PM   #30
MR_FG_09
Will have
Cheers mate im also looking at upgrading front 6 pot brembo pads either pmu NS400 or winmax W1 i do the odd happy laps morning at QR would either pad do the job 90% street driven
But plenty of spirited driving
Also want to flush the brakes would 2 bottles of the A.P racing do the job
And are the wagner pads performance orientated or only for street duties
All freighted to 4226 cheers
