06-05-2015, 04:45 PM | #1 | ||
With da Warlords
Hi all.
Does anyone know the law regarding the parcel light, with a rear spoiler. If you have a spoiler with lights in it, do you need to have an active parcel shelf light for registration? Cheers
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
06-05-2015, 04:47 PM | #2 | ||
in vic legally you cant have both, not that that actually stops anyone
06-05-2015, 05:25 PM | #3 | ||
Almost as annoying as a rear fog lamp switched on unnecessarily. Obviously the required brightness is doubled with two lamps, so would be illegal.
ADR 60/00 specifies that there should be only one centre high mounted stop lamp. This would be applicable in all states of Australia. |
2 users like this post: |
06-05-2015, 06:00 PM | #5 | ||
With da Warlords
Awesome, thanks for clearing that up guys. Getting car ready for rego again and thought I'd ask
06-05-2015, 06:09 PM | #6 | ||
Wirlankarra yanama
Best and most accurate thing to do would be to email the question to Dept of Transport. If the answer is that you can dispense with using the parcel shelf light, then keep the answer in your glove box in case you find yourself in future law enforcement discussions.
07-05-2015, 07:40 AM | #7 | ||
The one and only
I've seen cars with both. Doesn't look good to me.
Usually the globe is removed when a spoiler (with light) is fitted.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
10-06-2015, 08:04 AM | #8 | ||
The one and only
Sorry for the double post.
I just took a car in for a RWC. One item that failed was the center brake light. Had to disconnect the one furthest from the back (as in the one in the window) As it is a high series the brake light was in the top of the window and wasn't blocked by the spoiler, but had to disconnect it anyway.
10-06-2015, 04:44 PM | #9 | |||
