16-03-2015, 08:54 AM | #1 | ||
Have Boost, will use it..
Front left corner of the ute is making this creaking noise when going over speed bumps or driveways.
Ideas what to check? |
16-03-2015, 09:16 AM | #3 | ||
Thanks Professor.
Anything more specific to be checking first? |
16-03-2015, 09:16 AM | #4 | ||
Sam, are you sure the creak is from the front left. I had and identified a creak coming from the right rear shock of my FG ute.
Jiggle the rear of the ute by hand, see if you can still hear the noise.
2010 FG XR6 I6 CC Ute, Nitro colour. lsd, sports suspension, Ford 18's fitted with Michelin Primacy 3 ST 245x45x18, MW Quick Shifter, Pacemaker 4500 Extractors, Carbuilders Soundproofing, KPM Street Fighter CAI |
16-03-2015, 09:55 AM | #6 | ||
Get a friend to push down on each corner of the car while you listen to see if you can hear the creaking noise.
My Ride... 2005 BA2 XR6 Magnet Ute. |
16-03-2015, 10:54 AM | #7 | ||
99% certain it is the front left. But will do the push down each corner test with a mate to confirm. It appears only on the rebound, I think.
16-03-2015, 05:48 PM | #8 | ||
Ball joints?
They'll usually make more noise when steering though. You could always stick the car on ramps, lay underneath & do some pull ups on the K frame. Trace the noise & get some exercise at the same time! |
16-03-2015, 07:09 PM | #9 | ||
Creak id say first up check sway bar bushes.
Generally any bush can creak depending. Never heard a shock creak, but also never installed an assembly incorrectly. Really need to get it on a hoist to locate it.
Current Car: 2002 AUII LTD 408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS Daily: 1998 Mitsubishi Super VR-4 Legnum |
16-03-2015, 07:52 PM | #10 | ||
Cheers guys
