18-01-2015, 07:59 PM | #1 | ||
Wanting to fix an AU II central locking problem. The problem is when the drivers door is locked with the key, all the doors lock apart from the passengers door. When I go and open the passengers door after this happens, all the rest of the doors then unlock . No idea why this is happening and any ideas of help would be appreciated
1987 Fairmont Ghia - Sahara Gold |
18-01-2015, 09:09 PM | #2 | ||
I would think you need to buy a new lock actuator from the wreckers , bought one last week for 65 dollars, easy job to install , this is very common on these cars so I am pretty sure this is your problem.
19-01-2015, 08:30 PM | #3 | ||
Okay will give this a try hopefully will fix the problem
20-01-2015, 08:55 AM | #4 | ||
you can buy the gears for them off ebay
2000 AU Wagon |
20-01-2015, 06:10 PM | #5 | ||
It will probably be cheaper and easier to go to Pick a Part and get a secondhand one and just try that, does anyone know if the actuators are the same from ELs as the AU ones
20-01-2015, 08:57 PM | #6 | ||
no , completely different
2000 AU Wagon |
20-01-2015, 11:25 PM | #7 | ||
Next upgraded Mk1 Leopard
That's what I thought
UK
24-01-2015, 01:46 PM | #8 | |||
Former BTIKD
I bought two reconditioned ones from these guys, never had a problem with them. If you don't want fully reco ones, they sell the repair kits for about $22 http://stores.ebay.com.au/STRUT-ACTU...=p4634.c0.m322
