Old 20-09-2014, 11:18 AM   #1
kassan1973
Default Au climate control
Hi all are the Au climate controls able to be programmed so that the AC does not come on when heater is in recirc mode.
Thanks Dean
kassan1973 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2014, 09:15 PM   #2
mif73
CNC fixer guy
mif73's Avatar
Default Re: Au climate control
I would say no but others may know better.
Otherwise just hit the ac button again to disengage the ac compressor.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player.
Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers.
mif73 is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2014, 11:12 AM   #3
kassan1973
Then it revirts back to fresh air again will only stay on recirc with ac on.
Old 21-09-2014, 04:09 PM   #4
Davehoos
a/c supposed to be on with the heater-if you don't want the compressor on pull the clutch relay or add a switch - just had an interesting ride with mum turning things on off every few Km because a heater is a heater and a/c is for cooling. even in semi auto mode the system looks at outside temperatures light conditions to coe up with best[programed in ] modes.
If it thinks the outside temp is low it will naturally select recirc. same as if the water temp wasn't up to spec. I thought you could get it into manual mode selecting bi level or face.
most recirc doors have brocken the control lever and you add a screw to hold the door open/up to get the a/c down to original spec temperatures.. remember to open a window to flush out the chemicals.
BF11 XT EGas Wagon-SY TERRITORY AWD GHIA-
Land Rover 88
.MIDCOAST NSW.
Davehoos is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2014, 07:45 AM   #5
mif73
CNC fixer guy
mif73's Avatar
Checked mine yesterday.
yeah. you cant have recirc mode with ac compressor off. Bummer.
Old 22-09-2014, 01:07 PM   #6
Davehoos
fresh is mostly for demist.
Land Rover 88
.MIDCOAST NSW.
