ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link |
Hi I am after some help. I have read every ICC post prior to changing over my standard single zone 1xCD ICC over to a second hand premium DZ 6 stack.
I removed my old BEM and fitted it to the six stack ICC. also swapped over the little remote control module just in case. Vehicle started no probs but no radio or AC. Also fitted a second hand LHS wing mirror with temp gauge with new wiring loom in door for this back to the big connector plug from door to vehicle body near hinge. Took vehicle to local Ford dealer as I was getting code error on screen, which I expected. They tried to match in and reprogram BEM but could only get radio to work. AC, fan temp does not work. When I press the AC button it comes up "AC OFF" when actually the AC compressor is on and vice versa. So no AC. I expected from reading posts that as I hadn't fitted the additional actuator rod and motor that it would work as single zone from the passengers side temp control only. Also it had six CDs in the stacker which all eject ed ok but will not accept any CDs at all. And no outside temp coming up on screen either and no AC temp coming up on screen. HELP! Getting a bit over it. Any advice appreciated Cheers Gavin |
#2 | |||
Sponsor
from memory we spoke yesterday on the phone??? Sorry we dont get involved in this upgrade, too costly and too may problems we usually upgrade the car leaving the single climate but adding a color screen with single cd or 6cd acm cheers fadi75
FROM FALCON BA THROUGH FGX, TERRITORY SX THROUGH SZ - ICC UPGRADES, REPAIRS & INTEGRATION SPECIALISTS AUTHORISED FORD REPAIR CENTRE website: www.aslautomedia.com.au email: info@aslautomedia.com AUDIO INTERFACES, REVERSE CAMERAS, SATELLITE NAVIGATION & VIDEO INTEGRATION ON FACTORY COLOR SCREEN |
#3 | |||
BOSS Pilot
You need to get the HIM recoded as well. Ford should be able to do it or if you have a elm327 device you can do it yourself easy enough with this guide
http://www.fordforums.com.au/vbporta...commentid=1437
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
