The lease is up on the Ford Territory and I have replaced it with a Mitsubishi Outlander PHEV. Ok, I know this is a Ford Forum, but I thought there might be some interest in what it is like to drive with this technology. Does it make financial sense? No. But, it was a toy that I wanted to play with, and that is a good enough excuse for me.
The basics. The PHEV mechanicals fits inside a standard Mitsubishi Outlander. It has a 12kWh battery bank under the floor (about 9.6kWh usable), 60 kW electric motors front and rear, and a petrol engine rated at 89kW connected to a generator. The battery has enough energy to drive the car about 52 km under perfect conditions. However, turn the air conditioner on and the range drops dramatically to around 37km (or worse depending on how hot it is). Unlike the Tesla, it is not going to win any traffic light drags. In fact, it is probably as slow as the diesel Territory off the mark, and only slightly faster to 100kph. For a normal take off, the throttle needs a decent push (for my liking), but once rolling the acceleration is OK and very linear. As long as the power draw stays under 60kW, it will accelerate on battery. Acceleration is eerily quiet, with just a far off electric whirl, almost like the noise from inside an electric train. Above 40 kph, road and wind noise overtakes the sound from the electric motors. Sitting on the highway at 100kph, the combination of road and wind noise is, to my ears at least, louder than the inside of a diesel Territory. It is quite happy to cruise at 100kph on the highway just in battery mode (while there is still juice left). If you have a Honda inverter electric generator, you’ll get the idea of how the petrol-generator combination works in the Outlander. Under Wide Open Throttle, the petrol-generator kicks in with a single note roar. Sort of sounds like a sewing machine on full revs. As the throttle closes, the engine cuts back to a moderate, almost indistinguishable hum. And, if it can, the petrol engine throttles down and turns off. If the battery is flat and the engine is left to its own devices, it cuts in and out while driving in peak hour traffic. Occasionally, one pulls up at the lights and the engine is burring away at full bore. It then shuts down, and when the light turns green, one moves off in almost complete silence. There are two buttons on the centre console. One tells the engine to recharge the battery. In this mode the engine runs at low speed, but flaring to higher revs when called on to provide additional power. The other mode is a charge hold mode. In this mode the petrol engine-generator does most of the work, leaving the battery charge as is. Unlike an engine connected to a mechanical gearbox, the engine revs do not rise and fall as the car works its way through the gears. Instead, the engine picks its revs to suit the power demand at the time. The revs rises to one set point and holds it – delivering constant power – until it is called to go to another rev set point. On battery, I can get to work and nearly all of the way home. The engine only cuts in a few times, mainly because I want more acceleration when climbing up hills from rest. Fuel consumption into work is around 0.8l/100km of petrol, plus electricity around 20 kWh/100km. I haven’t had a clear run back to home yet, but I drain the battery around 10km from home and it then costs me around 3l/100km of petrol (total average for the trip). For the sparkies amongst us, the vehicle requires a 15Amp socket outlet. Current draw is around 13.3A. It has a soft start system, which takes around 10 seconds after being turned on before it draws any current. For the first few minutes, it is only drawing around 5 Amps (I should put a tong tester on it sometime). While I haven’t sat and watched it, by 30 minutes later, it is drawing full current. It takes around 5 hours to reach full charge, tapering off the charging rate as the battery approaches full. The PHEV has an onboard timer that can be set to draw power at the cheapest rates for those on Time of Use tariffs. It is quite happy with interruptible tariffs. In my case, the PHEV is parked in the carport. The first concern is that the charging lead costs $1,000 to replace! And, knowing the neighbourhood that I live in, having someone take the lead (even as a souvenir) is a concern. There is no way to “lock” the lead to the vehicle or the wall. My temporary solution is to mount the charge controller in a jiffbox to make it harder for a random to just pinch it. As electric cars become more popular, there is going to be real issues with people pinching charging leads (especially at $1,000 a pop), just like there are issues today with people stealing GPS navigators out of cars. The manufacturers really need to get their head around this concern and move the electronics so that a simple (and cheap to replace) 15A extension lead will suffice to charge a car. Or, somehow, make the lead lockable to the car. The nicest complement about the PHEV is that it does not look like an electric vehicle. It is just as bland as any other Japanese SUV. Steering is OK. It could do with more feedback, but tracks reasonably straight. Suspension is very stiff (to control the extra weight) and it bounces around on surfaces that the Territory would just glide over. Driving position is not as good as the Territory, seating is very upright and lacking support. Nor is the handling. On the open road, the Territory wins hands down for refinement, driver comfort, and drivability. Around town, it is a slightly different story, particularly in peak hour traffic. The Outlander PHEV is almost silent. In fact, 99% of the objectionable noise is coming from the other cars and trucks sharing the road with you. The Adaptive Cruise Control works well. Haven’t triggered the Forward Collision Mitigation, yet. The ergonomics of the central display is a nightmare. In terms of build quality, I have not spotted one fault or flaw. It is exceptionally well screwed together. Lots of attention to detail. There is some interesting technology on the car as well. For example, the air conditioner compressor is electrically driven. If the engine is cold, there is a water heater for internal cabin heat. The battery pack has its own liquid cooling system. A timer can be set to electrically cool/heat/demist the cabin; all done in silence. The PHEV is a fascinating insight into where automotive technology is heading. One thing is for certain, the automobile is not dead. Nor is it going to die when oil eventually runs out. The future for the automobile and the automotive industry is now more exciting than it ever was. |
#2 | |||
Sling Shot
The real question, does it do a burn out?
4 users like this post: |
Thailand Specials
Awesome to hear about these things, out of curiosity whats the life on the battery bank and how much over the counter for a new battery bank? Whats involved in changing it out?
Are there any slow charge options when its plugged into the wall rather than fast charging it? As fast charging significantly reduces the life of batteries. |
Boss 335
How do I tell if a power socket is 15A? Lucky enough to have a standard 240v power socket in my car space. Wouldn't mind free motoring lol
Thanks for taking the time to provide a review on your PHEV. Sounds what I was expecting.
It will have a large earth pin/socket on it.
Current Rides: 2017 Ford Mustang 2020 Ford Everest Sport Past Rides: 2017 Kia Stinger GT 2008 FG XR6 Sedan 2008 FG G6E Sedan 2004 BA XR8 Sedan 2008 BF XR6 Turbo Sedan 2004 BA XR8 Sedan 2003 BA XR8 Ute 2003 BA XR6 Sedan |
Thailand Specials
#7 | |||
Plugging it into a 15A socket is the "slow charge" option. Looking at some of the charge curves I have seen on the internet, it starts in slow charge mode, then moves to a charge rate around 3.2kW/h, and then tapers off to a trickle charge in the final part of the charge. A fast charge occurs at the charging station and will take it to 70% charge in 30 minutes, before dropping into trickle charge mode. Battery has a five year/ 130,000 km warranty. Design life is 65% capacity after ten years. If one can believe the internet chat ... apparently, the battery bank is grouped into 3 X 4KW cells. By design, one set cops the most work and one set is worked very little. The set that does the most work has the shortest life. The idea is that if battery performance is down, swapping out the first 1/3 will restore most of the capacity. Changing the entire battery bank costs around $12K and takes 2 hours. A good home mechanic should be able to do the battery swap. The other point to keep in mind is that the price of batteries is falling. In ten years time, I would expect replacement batteries to be half the cost they are today and will have significantly more capacity. It is quite possible that someone will do a battery swap on the PHEV in 10 years time for the equivalent price of a new ZF gearbox and have a 24kWh battery bank as a replacement. |
5 users like this post: |
Thailand Specials
What sort of voltages are we talking about here with the battery bank? Because some hybrids are doing around 600V and there is currently no training for apprentice auto electricians going through today about the dangers of these vehicles.
This is something you don't want your back yarder, mechanic or apprentice fiddling about with a test light or uninsulated tools if hybrids start rolling into their shops after the warranty period expires. |
Would you believe it could pull the skin of a rice custard?
Err, no. Unfortunately, no burnouts. For starters, it has full time AWD. Electric motors produce their maximum torque from rest. Apparently, the front and rear electric motors in the PHEV have slightly different gearing ratios to give a better spread of acceleration across the speed range. That means less low down urge out of the PHEV. But, it doesn't mean that electric vehicles cannot be fast http://www.topgear.com/au/videos/electric-shocker |
#10 | |||
Yeah, I agree. There are a new set of safety challenges with the electric electric vehicles. While the high DC voltage is an issue, the bigger concern is the fault current that these batteries can generate. A short circuit with a spanner in the wrong spot will produce a really big ball of plasma. However, using proper insulated tools combined with a good work practice and it should not be an issue. But, to keep a sense of perspective, petrol and LPG are just as dangerous in inexperienced hands. Interestingly, the Qld Electrical Safety Act has a specific clause that excludes electric vehicles from the Act. |
#11 | |||
Thailand Specials
https://www.youtube.com/watch?v=SVkJjt_Peg0
Electric E36 BMW, 850ftlb torque at the wheels. They go for a spin in it too and comment, its alright to watch. Quote:
Kangan Institute was running a course for Nissan mechanics for the Nissan LEAF and they did a short course in Hybrids before the government cut heaps of funding to TAFE and the teacher got let go. There is nothing covered in the course for auto electricians which is scary. Also what about emergency services? If the fire fighter needs to cut you out and cuts through some wires carrying high voltage etc. The problem with common sense is whats common sense for me as an ex auto electrician won't be common sense for someone else, I can see it when I pop the bonnet on peoples cars and see some odd DIY wiring jobs or wiring done by LV mechanics with good intentions but poor execution due to lack of knowledge/training in that area and thats only with 12V, worst case scenario you set your car on fire. With 600V worst case scenario is your death and this is where the Government is going to have to step in before this technology becomes mainstream and sort out legislation, regulation and training requirements before we get casualties. This problem will probably start occuring in 15-20 years time when the technology picks up and becomes standard and we've got AFF members swapping out battery banks and changing wiring to make their cars faster. Last edited by Franco Cozzo; 06-07-2014 at 02:11 PM. |
#12 | ||
Now Fordless
I've driven a few of these and they seem ok. Bit strange at first. Actually going to the intro course for it in a couple of weeks so will be interesting to find out the specs.
#13 | |||
Found these instructions about how to work safely with a PHEV. It looks like a Dutch version translated to English using Google. But, there is enough there to get the general idea of the challenges with large battery banks. http://insideoutlander.boards.net/th...tch-mitsubishi |
#14 | ||
Thanks for the review
I replaced my wife's 07 territory with a 2013 MY14 ES and liked it so much I got an 2014 MY15.5 AWD LS as my work car and like your review it's not one for dragging at the lights but in every other aspect it's a great 7seat family car
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
#16 | ||
Peter Car
How can you handle the look of the thing. One of the most boring, bland designs I have seen lately. Mitsubishi styling has been a massive fail of late.
But in saying that it they have done well to price it where they have. Even cheaper than a Holden FvOLT which is much smaller and 2wd. |
#17 | |||
Boss 335
#18 | ||
Running at a higher voltage reduces resistive losses in the cables, so the conductor size can be smaller for the same power transfer. The voltage chosen is a tradeoff between the additional expense for the higher voltage and the additional expense (and weight) of thicker conductors for lower voltages. I think the voltage in the PHEV is around 300V direct current (DC).
#19 | |||
http://www.ford.com/cars/focus/trim/electric/ |
#20 | ||
Render unto Caesar
Good to see Mitsubishi doing this. Finally we (AU) get this technology in something useable at a decent price (Lexus RX450h is beyond the means of many).
I was very skeptical initially of the plan but I have read a few positive reviews of it. I'd be keen to drive something like this for a week to see how it goes. So much win with other makes introducing this into their range. thanks for the review.
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson |
#21 | ||
BANNED
Great positive revue...pity it's not a Ford.
Mitsubishi have stated that they are embarking on a global emphasis to electric/hybrid cars. So much so that north American manufacturing has stalled all petrol based engine manufacturing.... Is anyone at Ford...or Holden for that matter listening? Missed the boat. |
#22 | |||
See this http://rvcs-prodweb.dot.gov.au/pls/w...TERRITORY+2+EV |
#23 | ||||
Thailand Specials
If you have high voltage you have less current, if you've got low voltage with huge current you need huge wires. Imagine how many amps you'd need at 12V instead of 300V and how thick the wires would have to be to deal with that much current? |
#24 | |||
Peter Car
The Holden Volt is selling in single digits. |
#25 | |||
#26 | ||
#27 | |||
BANNED
Well since they don't offer a single one we'll never know if Ford could sell any or not. Just shows to me that they really don't care about being open for business. Stocking zero of anything is bad management. Just because red jelly beans sell more than black ones doesn't mean you only sell red ones....makes a boring shop. Yes... but it's not a particularly good example. Tesla are up to 30,000 cars a year with a waiting list three city blocks long. |
#28 | ||
BANNED
#30 | ||
So with an average of about say 20kWh/100 this would roughly equate to about $6 bucks a 100km in recharge costs (using approx 30c/kWh)? Enough to justify the outright cost of vehicle? Unless you can couple it to a solar system it still would add up, but the disadvantage is that the time you'd like to charge would be when you get home at night. Off peak supply would make sense providing your local energy provider allows it. Would be good to see theme beginning to make provision for this tech.
