22-05-2014, 04:05 PM | #1 | ||
Cougar Owner
Just noticed that the coolant is bouncing about in the expansion bottle chamber above the main hose.
When the revs change as the a/c compressor cuts in and out it sends a spurt of coolant into the bottle. It doesn't look like bubbles from a head gasket and the engine is running OK and not using any coolant Is this normal or the signs of a head gasket problem
Leon AUIII XLS with Tickford bits, 1968 XR7 (302W 4v roller cam), 1969 Convertible (302W),
22-05-2014, 04:36 PM | #2 | ||
Not normal but check for soft/ collapsing radiator hoses and try a new pressure cap first.
regards Blue |
23-05-2014, 10:54 AM | #3 | ||
5.6L x 2 pilot
I have had the same problem. Change of radiator cap and thermostat corrected the issue.
Cheers Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
23-05-2014, 06:42 PM | #4 | |||
Then clamp off the hose from the thermostat to the bottle-the radiator may need clogged.
BF11 XT EGas Wagon-SY TERRITORY AWD GHIA- Land Rover 88 .MIDCOAST NSW.
