Old 21-04-2014, 03:42 PM   #1
MadadNZ
Default Thermo Fans run when ignition turned on car won't start 2.5 telstar
hi
my 1992 2.5v6 telstar started stalling,not starting and both thermo fans run when ignition is on
on the occasion it did run when thermo fans came on it stalled
have replaced fuel filter any other advice would be appreciated
MadadNZ is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2014, 05:30 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default Re: Thermo Fans run when ignition turned on car won't start 2.5 telstar
the air con cooling fan should come on with the air con on
both fans check fuses and or relays
have to check if both fan motors are not burnt out (possible)
next if no thermo switch in base of radiator to start them
that fan may be controlled through ecu ... bit its not a new model
My car goes Brumm Brumm
