06-04-2014, 07:50 PM | #1 | ||
I have an au series 3 forte with 158000km..
car drives great. But noticed sometimes from a standing start, if you give it a decent shove to takeoff it has a slight hesitation and then then goes. Like a slight miss and then shes away. Not always but sometimes? ive noticed that if it sits in drive for a bit (like at the lights) and then more than half throttle it just hesitates and then goes. when driving or kicking down a gear etc never does it. If in neutral and just rev it all of a sudden its fine. Never does it in any other scenario and not always.. car has plenty 98 fuel in it, recently run fuel injector cleaner, new air filter, new fuel filter, new spark plugs, cleaned throttle body, new cat converter and exhaust. Car idles smoothly. Im thinking a dodgy lead or coil? Or fuel pump? But never does it at high revs or any other scenario. Only standing start when sitting in drive for a while at low revs and then give it a bit of throttle all of a sudden. any ideas?? Im being picky but i like my cars perfect. |
06-04-2014, 08:10 PM | #2 | ||
Drive'n Cruise'n Live'n
My EF11 did this after about 2-3 minutes from cold and new Oxy sensor fixed it. Au3 O2 sensor is due for replacement at 150,000km.
06-04-2014, 08:15 PM | #3 | ||
Au Falcon = Mr Reliable
Hi there, make sure your intake manifold bolts are tight & also check each cylinder for spark quality, it may be down half a cylinder due to yellow spark.
Check if your transmission is a little low on fluid. If you can get hold of a ecu scanner, do a scan & see what comes up. Also check your o2 sensor like xc50077 suggested. Good luck! cheers, Maka
06-04-2014, 08:40 PM | #4 | ||
RIP...
This was the problem on my brothers AU a couple years back, vacuum leak.
We had to change the intake gasket.
. Oval Everywhere... |
08-04-2014, 10:07 AM | #5 | ||
I have the exact same problem on ours..was soo bad one day that we actually stalled in the middle of an intersection!
09-04-2014, 09:28 PM | #6 | ||
Ive ordered an 02 sensor.. ill report back if its the fix.
14-04-2014, 02:13 PM | #7 | ||
O2 sensor arrived so will fit up tonight.
Update is that it seems to have a. Initial hesitation on heavy changes in throttle. Light throttle car is ok but give it a stab off the line there is hesitation and the. She's off.. Or going around a corner and then punching the throttle there is hesitation? But revving flat stick (after initial hesitation) right to redline the cars goes beautifully. |
14-04-2014, 11:02 PM | #8 | ||
Changed o2 sensor but problem remains.
14-04-2014, 11:50 PM | #9 | ||
mmm, maybe coilpack, dirty fuel filter, fuel sock, fouled up plugs, hi resistance in leads. Lots to check, change fuel filter, fuel sock, and plugs, there all about $20/30 each, then id probably look at the fuel pump or coilpack
15-04-2014, 10:06 AM | #11 | ||
The fuel sock is a filter/strainer located on the fuel pump inlet port.
cheers, Maka
15-04-2014, 10:11 AM | #12 | ||
RIP...
I still have my money on this...
15-04-2014, 10:29 AM | #13 | |||
seems to just hessitate under load, on hard takeoffs just a slight hesitation and she is away. when cruising its fine. idle is perfect Also now noticed if you are cruising and hit the throttle it hessitates and then goes. I think its getting progressively worse. now ordered new leads and coil pack. try them out when they arrive. Ive heard changing the coil pack is a pain in the bum. |
15-04-2014, 10:31 AM | #14 | ||
Racing improves the breed
Is it better or worse depending on the amount of fuel in the tank? Sounds like the same thing I had with my old XR6 VCT. It was generally worse with a lighter load of fuel on board and taking off after making a turn it would surge. It was the fuel sock.
1970 Mini Cooper S Historic Group Nc Touring car 1964 Mini Cooper S Historic Group Nb Touring car 2024 Subaru Outback Touring XT Victorian Hill Climb Championship |
15-04-2014, 11:33 AM | #15 | ||
My fuel pump actually died, so I replaced it with a gss342, problem fixed
15-04-2014, 05:43 PM | #16 | |||
RIP...
16-04-2014, 12:47 AM | #17 | ||
Any benefit in pulling out the fuel pump and attempting to clean the fuel sock?
Anything to watch out for? Should I just get a new fuel pump? I already have a coil and leads coming from ebay.. The issues seems to be getting worse on a daily basis, coincidence that my fuel levels are less and less each day also? I'll give it some new fuel tomorrow and see if it effects condition |
16-04-2014, 12:51 AM | #18 | ||
yeah I don't think the fuel sock can be cleaned, new fuel pump is is about $150 for a walbro and 3 hours labour, standard is $60 and about 2 hours labour
16-04-2014, 11:25 AM | #19 | ||
I would check your spark before looking at the fuel pump. Get a spare plug & assistant, remove a lead, fit old plug & earth out plug on tappet cover. Start car & without zapping yourself, observe colour of spark, blue - good yellow - bad, repeat for all spark plugs. Wont cost nothing good luck!
cheers, Maka
16-04-2014, 03:06 PM | #20 | ||
UPDATE
fitted new fuel pump (+ new fuel sock) and fuel filter and full tank fo fuel. still has hesitation problem...grrrr!!!! fuel sock pretty black and looked abit gummed up so prob good i changed it.. Anyway coil and leads should arrive today or tomorrow so I will replace them over the long weekend and see if it fixes it.. AU is supposed to be super reliable!! |
16-04-2014, 03:33 PM | #21 | |||
RIP...
Change the manifold gasket and all will be fine.
16-04-2014, 06:56 PM | #22 | |||
We had similar issues on our territory, and intake gasket fixed that too, and it idled ad ran perfectly, except for the slight miss on hard acceleration.
16-04-2014, 07:09 PM | #23 | |||
Cold the car is ok, but as soon as it heats up a bit seems worse. Wouldn't intake manifold gasket leak more when cold? Seal up when hot as it expands? Also seems to be getting worse almost daily. A few weeks ago all good and gradual decline.. Intake manifold bolts are tight. Last edited by HULK_I6T; 16-04-2014 at 07:18 PM. |
17-04-2014, 10:35 PM | #24 | |||
18-04-2014, 04:24 PM | #25 | ||
Replaced coil....
so far...... problem solved!!!! No more hesitation at all. I drive it for a few days and see how it goes. took about an hour to change.. remove airbox and arm under... socket extensions with 7mm bit to remove coil.. |
18-04-2014, 04:27 PM | #26 | ||
Good stuff Hulk.
18-04-2014, 07:09 PM | #27 | ||
Yep, good work.
18-04-2014, 08:06 PM | #28 | ||
Strangely i bought leads but they wont stay on the plugs. They pop off so to speak. You hear em click in but as soon as you let them go they pop back..
should I cut them back a bit on the ends? Maybe too long? The standard leads fit beautifully. the miss is gone whicj suggests my leads are good anyway. |
19-04-2014, 07:52 PM | #29 | |||
Walking with God
Glad you got it sorted. GK
